Bose system expansion
Old Jan 15, 2004 | 01:15 PM
Fry's Avatar
Fry
I've got a 96 Z28 w/the stock Bose system.
I'm wondering, can I, or is it possible to expand the rear subwoofer compartment there and just fit in a larger woofer?
Also, is it possible at all to modify a the stock deck to play MP3's?
Anyone with any experience in these areas?
Cheers
Adam
Old Jan 16, 2004 | 05:36 AM
LS1 RULZ's Avatar
Re: Bose system expansion
No, you need to replace the entire sub and sub amplifier. BOSE uses odd impedance drivers in it's systems. You can't just drop in any speaker.
No. You'll have to go with an after-market system to do that. Or get an FM modulator CD/MP3 changer and add it to the stock stereo.
Old Jan 17, 2004 | 08:51 AM
Eliminator's Avatar
Are all the speakers amp. or just the rear sub? If you have the rear sub. is it possible not to have the amp. Circuit city said if you have bose you have the amp. system. Best Buy said it was a option to get the amp and not every bose system has the amp now who is right??? Anybody know?
Old Jan 17, 2004 | 09:16 AM
LS1 RULZ's Avatar
Every Bose system I've ever seen uses amplified speaker modules.
Old Jan 17, 2004 | 09:38 AM
Eliminator's Avatar
Thanks for the help.
Old Jan 17, 2004 | 05:00 PM
LanceJoker's Avatar
Bose does use wierd impendance.The fronts are wired at 4 ohms which is normal for cars,also makes it easy for replacing the door speakers should you want to.However the rears and sub (actually a mid-bass) are wired at one.Which absolutely screws you when wanting to replace or upgrade.You have to run new wiring for them.
Old Jan 18, 2004 | 08:31 AM
Eliminator's Avatar
So what happens when you run a 4 ohm speaker to the rear sub?? Ruin the radio or doesnt sound as good?
Old Jan 18, 2004 | 08:39 AM
LS1 RULZ's Avatar
Since the impedance is higher than the stock speakers the output from the new speakers will be much lower.
Old Jan 18, 2004 | 08:47 AM
Eliminator's Avatar
What ohm is the rear speakers at? I think i heard 1 ohm is that right?
Old Jan 18, 2004 | 08:49 AM
LS1 RULZ's Avatar
I don't know the actual impedance. I just know that Bose uses oddball impedance speakers. Like I've said before, Amar Bose doesn't like people to mess with his designs.
Old Jan 18, 2004 | 09:00 AM
Eliminator's Avatar
Man that sucks, cause i replace my rear with just a 8 inch 4ohm speaker for a little more sound it was ok the I put a 10 inch in it sounded better. So all I would be doing is under powering the speaker.
Old Jan 18, 2004 | 09:36 AM
LanceJoker's Avatar
Yes,That is correct.1 ohm on the rear mid and rear panel speakers
Injuneer
Apr 25, 2022 06:22 PM
pimpen1024
Aug 19, 2015 08:36 PM
jwright3SS
Jul 30, 2002 03:49 PM
96CamZ
Jul 27, 2002 04:13 PM
