pinging and major kr
Old Jan 14, 2004 | 06:54 PM
blacknight's Avatar
Caused by carbon buildup. I have done two treatments of using around 1/3 of bottle of Seafoam each time and still pings a lot and I get around 2-7 of kr at all rpm's and any amount of throttle. So performance is down big time. Should I just keep using more Seafoam until the pinging and kr stops? I have put on two nice smoke shows.
Old Jan 14, 2004 | 07:14 PM
96SFLZ's Avatar
You sure the carbon buildup is what's causing it? Especially after running SeaFoam thru.
My guess is that the DiabloSport tune is probably part of your problem. I had a little problem with pinging after Diablo tuned my car. Usually it was just during the day, when it was fairly hot...at night, it was fine (this was during summer, about a 6-8 month season here). I don't have a problem at any time now, being that it's only in the 70s during the day.
And what's the highest octane you can get over there? I believe I've read that 91 is the high at most gas stations in Cali...? I was running 93 and having problems so I can definitely see you having problems with 91.
Try bumping the timing back a little and see if that helps. Or try some octane booster, I know it's usually a waste but if you're only running 91 then it might get you up to 93 or 94+, which might help. Lastly, you could try setting the car back to stock (programming) and see if you still have any knock.
Old Jan 14, 2004 | 07:50 PM
blacknight's Avatar
The stock tune has been in the car for a couple months now and the dealer reflashed the pcm already. It pings even in 40 degree's. I was up in the desert during christmas in 40 and below weather and it pinged. We only have 91 octane fuel here but I have been using that for over a yr and it didn't start pinging until I started driving alot. I have tried all brands of gas and it doesn't matter. I am almost 100% sure it's pinging because of carbon since I made a nice white smoke show today after using the Seafoam. I have a catch can system I made using a air compressor filter and it collects a descent amount of oil, about 1 -2 teaspoons in 400 miles. Time to go to the dealer and be a jerk to get them to fix this and all the other problems. By the way my LT's are negative and 0 at wot . Also the plugs are black from all the carbon. I have a set of NGK's 55's coming in the mail tomorrow but first have to clean the motor out. I have 1 and 1/2 cans of Seafoam.
David Dempsey
Mar 12, 2016 12:42 AM
mlopezart
Sep 8, 2015 12:15 PM
ZXXVIII
Sep 1, 2015 10:13 PM
WPHIG2
Aug 27, 2015 06:37 AM
meissen
Aug 11, 2015 06:05 AM
