I shot the gas, broke, now i got to pull the heads. Tell me what i may be dealin with
I went to shoot my car, a little more gas then usualle, please dont ask how much. At the beginning of second i shot it. Went fien for a few seconds then i lost power and my mistake, i stayed on it longer then i shoulda. I coasted down, gavce it some gas was car was studdering, popping, and skipping. I barley limped home. Today i pulled the plugs and they looked worse then any plug i have ever seen, on the internet or anywhere. The electrodes were burnt off, on some the plastic was even melted only a few of them could have been fireing barley. I put in new plugs, it cranked right up and idled alot stronger then the burnt plugs obviously but still skipping and smell of gas out the exhaust. I pulled some of the drivers side plugs tonight and did a compression test of 3 of the cylinders, two were good and one got no reading. It was dead. TOmorrow my buddy is going to help me pull the heads to see if hopefully its jsut a valve.... WHat are chances of the bottom end being damaged??? Hopefully, not a piston(s).
You would be best off doing a leakdown test before you go to the trouble of taking the heads off. That will tell you if your intake, exhaust, or cylinder is leaking. Just listen for air coming from the intake or the exhaust ports when you do it. If your plugs were that bad it probably detonated and anything could be damaged when that happens.
You said that you got no compression from one cylinder. That cylinder has a slim chance of firing with no compression, but it could fire every now and then. If you do a leakdown you should get a very obvious leak somewhere.
Most likely cranked the piston at the ring lands. I did the same thing on my car when it was stock. Did any of your spark plugs look like anything had came into contact with them. For example, did any of them have knicks or dents in them? My #7 piston had 0 compression too. Time for a rebuild with some forged stuff.
Good Luck and let us know what you find
Matt
Matt
You've trashed a piston, almost for certain. Eagle and Scat have some nice stroker kits for less than $3K, for sure. Good luck, and please post how much you were spraying. It will provide some info for those people who always ask "how much nitrous can I spray".
Rich Krause
Rich Krause
Originally posted by MrDude_1
its junk.
sell me your 9"
its junk.
sell me your 9"
