WTB LS1 stock injectors
Old Jan 10, 2004 | 04:04 PM
RE AND CHERYL's Avatar
Cool WTB LS1 stock injectors
I'm looking for a stock set of injectors from a 98, 01, or 02 LS1. They should be 28 or 29 LBS.
REANDCHERYL@MSN.COM
Old Jan 11, 2004 | 09:07 AM
QCKZ28's Avatar
i have a set of stock injectors from a 96 lt1
24lb at 43.5 psi
jesse
Old Jan 11, 2004 | 11:43 AM
Zepher's Avatar
Are these going on a non-LS1 motor? If so, then you need to notch them so that the injector clips will work (these are the round clips the hold it to the rail) also, LS1 injectors operate at higher PSI than the LT1/TPI so the # rating is going to be different, 28# LS1 injectors on an LT1 will be 24#.
I bought a set before I knew about the PSI ratings.
I've got a set of 99 SS injectors, 26# I believe, for sale.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
spearous
Jan 12, 2015 11:03 AM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
