Question regarding turbo install
Old Jan 10, 2004 | 02:17 PM
SMOKNZ's Avatar
Was in the process of welding up headers today and when the turbo was resting in it's final place, it was slightly tipped on it's horizontal plane.
My question is do the turbo's need to be exactly parallel with the ground, or can they be tilted some?
This twin setup is coming along just fine! All I have had to get rid of is the AC compressor and lines, and relocate the battery to the rear. Stock accessory bracket will remain in place! Only hurdle will be to get the 1LE pulley and modify the bracket to sneek the 3" downpipe thru, and rerouting of the heater core and powersteering lines, but that doesn't appear to be a problem.
Just wanted to know if the turbo will be a problem, the header is tacked right now with only one primary on it, but now is the time to correct something, if you know what I mean!
Bill
Old Jan 10, 2004 | 03:05 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Thumbs up
Corky Bell states in his book they can be tilted up to 30 degrees, but the less the better.
Old Jan 10, 2004 | 04:08 PM
SMOKNZ's Avatar
I looked in Maximum Boost and the only reference that I could find with the 30 deg's is for the oil inlet and drain. Could you point me in the right direction if I'm missing something?
Bill
Old Jan 10, 2004 | 04:36 PM
INTMD8's Avatar
You're right, I was looking at the picture thinking it was from the other side.
I'm not sure than how much you could actually tilt it, but there has to be some allowable deviation from perfectly level.
How many degrees do you have it tilted?
Old Jan 10, 2004 | 04:38 PM
SMOKNZ's Avatar
About 10 degs or so. If I put it perfectly level the hood height adjuster in the front corner will be in the way of the intake elbow.
Bill
LeftoverChinese
Jan 14, 2024 03:03 PM
Highlander
Jan 12, 2020 02:13 PM
blac94Z
Jan 22, 2015 11:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
Chrisdude
Jul 24, 2002 02:25 PM
