Window wont roll down (not motor)
Old Jan 10, 2004 | 01:00 AM
RedBeast93Z's Avatar
Question Window wont roll down (not motor)
Hey I have a 99 TA and the passenger window wont roll down unless the door is open. The motor isn't bad because when the door is open it works fine. I think its misaligned or something. Anyone know how to fix this or where i would take a problem like this to??? thanks a lot guys.
-Ryan
Old Jan 10, 2004 | 11:58 AM
wrencher's Avatar
Well I say check the wiring between the door & the body inside the accordian.
They might be damaged?
Seen B-4 mostly on drivers door, but ???
Can you hear the motor or see it dim lights with the door closed w/you push the button?
Do you think it is binding or not running the motor?
Old Jan 10, 2004 | 12:04 PM
oh ya, sorry I forgot to mention that when the door is closed and you try to lower it, it makes a loud CLICK CLICK CLICK!!!!!
Old Jan 10, 2004 | 01:19 PM
99blackSS's Avatar
Here's my theory: I think something is causing resistance (maybe something is wrong with the tracks, might just need grease) and that when the door is closed the additional resistance caused by the weather stripping causes to much strain on the motor.
Old Jan 11, 2004 | 04:25 AM
TXZ28LS1's Avatar
just like what 99blackss said it might need grease. my windows too are slow as hell to go up and down. i went to autozone and bought some silicone spray and i still havent done it yet, but roll down your windows and spray all that stuff in there...
Old Jan 11, 2004 | 11:50 AM
ok guys, thanks a lot. Ill give it a try later today and tell you what happens.
cmyname1
Feb 19, 2015 08:38 PM
warmeck
Feb 2, 2015 12:44 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
The Seer
Nov 20, 2014 06:32 AM
