connecting speakers? Stupie here.
Old Jan 9, 2004 | 11:15 PM
1badLS1M6's Avatar
Hey guys,
I'm speaker-stupid. My driver side speaker is blown. I have the door trim off and my new speaker will be here any day now.
Question is how do I hook up the speaker wire to the new speaker? I just cut the blown speaker from the speaker wire.
Now, when I get the new speaker, do I just twist the wires together? Or do I have to solder them?
Please help the ignorant!!!
Chris
Old Jan 10, 2004 | 03:09 AM
PaulN64's Avatar
do you have a stock speaker or aftermarket? If stock, then it's just plug and play. If it's aftermarket, then make sure you note which one is positive and which one is negative and connect accordingly. If you are replacing stock w/ an aftermarket, then check the wiring at www.installdr.com and follow the wiring diagram for the pos and neg connection. Preferably, solder the wires together
Old Jan 10, 2004 | 10:46 AM
1badLS1M6's Avatar
The speaker is stock. It didn't seem to have a plug though, just permanently wired together.
Old Jan 10, 2004 | 10:52 AM
PaulN64's Avatar
if stock, then it's just plug and play. Remove the entire speaker baffle and you'll see the plugs
Old Jan 10, 2004 | 10:55 AM
1badLS1M6's Avatar
The DOOR speaker has a plug? I swear I didn't see a plug. Is it INSIDE the door? How far down on the wire is the plug?
Old Jan 10, 2004 | 11:01 AM
1badLS1M6's Avatar
I went out the the garage, and yes there is a plug. See? I told you I was a stupie!!
Thanks for the help!
Chris
Old Jan 10, 2004 | 03:27 PM
convertz's Avatar
Mine were right on the back of the speaker basket I believe
Old Jan 11, 2004 | 02:54 AM
PaulN64's Avatar
that's cool...that should take care of ya then
Old Jan 13, 2004 | 04:12 PM
1badLS1M6's Avatar
OK, the new speakers are from a 98 Z28 with a 2 prong plug. My car is an 02 Z28 w/ Monsoon and has a 4 prong plug. Can I force this to work? How do I hook them up?
Thanks in advance
Stupe, I mean Chris :-)
Old Jan 14, 2004 | 09:50 AM
1badLS1M6's Avatar
Anyone? I must not be the only guy thats in the dark about speakers. If I try to wire it so it will work, i'll probably blow myself up!
Old Jan 16, 2004 | 06:59 PM
1badLS1M6's Avatar
TTT
PLEASE tell me I can use '98 speakers on my '02.
karpetcm
Aug 14, 2015 03:02 PM
surreybrad
Aug 10, 2015 09:34 AM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Latronaxe
Jul 17, 2015 11:55 AM
