Is this an ss or not
Old Jan 9, 2004 | 09:28 PM
DarCwuN's Avatar
how can i tell if this is an orginal ss or not here is the vin 2G1FP32G3X2131541
here is the link to the pic of the manufacturers codes can some one figure this out and tell me if this car check out as an 1999 convertible ss.
http://home.comcast.net/~s.bari/wsb/...D-1267062.html
Old Jan 9, 2004 | 09:31 PM
dis3as3d's Avatar
Open up the drivers door and look at the RPO codes. If it came from the factory with the SS package it should have WU8.
WU8 - SS Performance Package/Appearance Package - Camaro
Old Jan 9, 2004 | 09:32 PM
DarCwuN's Avatar
dont have the car
Old Jan 9, 2004 | 10:03 PM
Demon SS's Avatar
you can call SLP and have them run the VIN in their data base and they can tell you. carfax won't tell you anything except that it is a Z28. I used to have the number for SLP as it is not the same one for buying performance parts but you can call that number and get the number you need to call from them
Old Jan 9, 2004 | 11:02 PM
99blackSS's Avatar
SLP has a forum for posting the VIN# to get the build number. I can't find the link though.
Old Jan 10, 2004 | 08:45 AM
RE AND CHERYL's Avatar
SLP's forum is toast, closed a few months ago. I don; t know if the vin# link is still floating around though.
Old Jan 10, 2004 | 01:12 PM
cerealtool228's Avatar
Go to a GM dealer and have them run the VIN ..... that way you can tell (by printable RPO codes & meanings) also if the car has been taken in at any GM dealer for work.
Old Jan 12, 2004 | 01:58 AM
Carlos01SS's Avatar
Re: Is this an ss or not
Do what I did, go to slponline.com, you'll see a phone number there, either give them a call or send them an e-mail asking them to check, they'll need your VIN number, that's about it.
Old Jan 13, 2004 | 04:38 PM
Grifter's Avatar
Just go to SLP's website and get the number. I had it but I lost it. It takes about 2 mintues, tell them the Vin and they'll tell you if it's a real SS or not. If you think it is, it most likely is.
Old Jan 13, 2004 | 05:07 PM
Greed4Speed's Avatar
IIRC a Y21 in the VIN designates it as an SS.
Old Jan 14, 2004 | 09:42 AM
SSCamaro99_3's Avatar
SLP Engineering
248-288-3888
Old Jan 14, 2004 | 12:40 PM
ZZed's Avatar
My 2000 Z28 has "Y21" in the VIN. If I remember my VIN codes, the "Y" designates the year.
Old Jan 14, 2004 | 07:16 PM
z28camaro94's Avatar
the vin doesn not identify whether or not it is an SS
Vin goes as follows
1st digit - Nation of Origin
2nd - manufacturer
3rd- Make and type
4th- Restraint System (Engine type for AMC)
5th- Carline Series
6th& 7th - Body Types
8th Engine Type
9th Check Digit
10th- model year
11 assembly plant
12-17th - plant sequence number
Old Jan 15, 2004 | 11:16 PM
DarCwuN's Avatar
Old Jan 16, 2004 | 12:09 AM
Gold Z's Avatar
Your car is a fully loaded Camaro SS. Bright Red with a very dark gray interior and a black top. A4 tranny, 3.23 gears. The key RPO codes are:
N73...17" wheels, restricted to Camaro SS
QFK...275/40R17 BW tires
V12...power steering cooler
WU8..sales pkg, Z28 SS
It's a genuine SS.
