'94 Z28 for sale, 13k$, Vortech S-Trim 9 psi, Fully forged bottomend.. check it out
Trying to sell my car to buy an LS1... car runs very good with totally stock PCM programming. Asking 13k, located in Northeast New Jersey. Cloth interior, 68k on body/tranny/rear and 3k on rebuilt motor. Exterior and interior totally clean... never dyno'd, never ran at the track (if i still have her in spring, she'll get a fresh dyno and 1/4 time)
Mods (I may have forgotten some)...
Motor
- Eagle Forged Crankshaft (stock stroke)
- Speed-Pro Forged 9.5:1 Pistons
- Speed-Pro Forged I-beam Connecting Rods
- Speed-Pro Forged Piston Rings
- Clevite Main Bearing
- Clevite Rod Bearings
- Crane Hydraulic Roller Camshaft (214/222 duration, 488/509 gross lift, 112 LSA)
- Fel-pro Head Gaskets
- Fel-pro Intake Manifold Gasket
- Fel-pro Header Gaskets
- Fel-pro Oil Pan Gasket
- Fel-pro Valve Cover Gaskets
- Melling High Volume Oil Pump
- Hypertech 160* Thermostat
Induction
- Vortech S-Trim Supercharger
- Vortech 2.95" pulley (9 psi @ redline)
- BBK 52mm Throttle Body
Ignition/Fuel Regulation
- Crane Cams HI-6 Fireball Ignition System (6500 RPM Redline)
- Vortech T-Rex EFI Fuel Pump
- Vortech Fuel Management Unit
- Taylor 409 8mm ignition wires
- 1200* ignition wire heat sleeves
- Bosch Platinum Spark Plugs
- 30 lb/hr Fuel Injectors
Exhaust
- Edelbrock Midlength Headers
- Edelbrock Offroad Y-Pipe
- Stock cat
- Borla Adjustable Cat-Back
- B&M 4L60E Shift Kit Improver
- Competition Engineering Polyurethane Transmission Mount
- B&M Holeshot 2400 Stall Converter
Braking
- VHT Painted Calipers (red)
- Brembo Carbon Fiber Brake Pads
Suspension
- BMR bolt-on subframe connectors
- Competition Engineering Strut Tower Brace
- Hotchkis adjustable rear panhard rod
Exterior Cosmetics
- Polished Billet Grille
- Rear "CAMARO" Bumper Inserts (Black)
- 17x9.5" Enkei wheels
- AVS Headlight Blackouts
- GTS Taillight Blackouts
- GTS Turn Signal Blackouts
- RKSport Solar Wing
- RKSport Black Carbon Fiber Nose Emblem
- 20% Tint on back window
- "Today's Menu: Smoked Vette" License Plate Bracket (Not really a mod, but cool anyway)
Interior Cosmetics
- Autometer boost gauge
- Autometer Air/fuel ratio gauge
- Eurolite interior neon kit (Two 9" sticks under console, very tasteful)
- 3A Racing pedals
Will take trades for stock or bolton LS1s only, I want to build my own LS1! Thanks for interest.
(Note: More pics available at request)
Motor
Induction
Exhaust
- Stock cat
Braking
Suspension
Exterior Cosmetics
Interior Cosmetics
- 3A Racing pedals
Dec 1, 2014 08:08 AM
1LEThumper
Jul 14, 2003 12:45 PM
