Help on choosing pulley size and reading/dealing with a compressor map...
Old Jan 6, 2004 | 02:03 PM
Birdie2000's Avatar
I want to pulley my T-Trim to get every last drop of performance out of it. I don't really know how to go about deciding this, but I do know that when I looked at the compressor map I couldn't figure out exactly what it's telling me. What pulley combo do I want? I do not know the current pulley combo, but I know that I have a 7" crank pulley that came off of the car for a different one to lower the boost. I'll be able to measure the current ones in a couple days. I plan on shifting somewhere between 6500-7000 based on the cam choice, and the motor is a 355.
Old Jan 7, 2004 | 03:51 PM
Birdie2000's Avatar
Anybody? Pretty please with a cherry on top?
Old Jan 7, 2004 | 05:22 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Re: Help on choosing pulley size and reading/dealing with a compressor map...
Than pulley it up so it reaches max impeller speed a few hundred rpm before redline. (IMHO).
I think it would be about a 7in crank and 2.75blower pulleys.
Old Jan 7, 2004 | 07:24 PM
Birdie2000's Avatar
That's kinda what I figured, and this is where my lack of knowledge in this department comes in. I was looking at the compressor map and according to it, the T-trim makes it's max cfm (1200) just below 50,000 rpm, whereas it's max rpm is 55,000. Why would I want to max out the blower like that, to give me more area under the curve? Also, how does psi play into all of this? Right now I'm pushing quite a bit of pressure through it, but not getting near the power it (supposedly) should be making with this much boost.
Old Jan 8, 2004 | 05:22 PM
Flip94ta's Avatar
I just want to mention that your TH400 and 12bolt may be sapping alot of the power you feel you are "missing" Especially if you have a high stall. The TH400 isn't a model for efficency, but is a very tuff piece. That being said, if you are making alot of boost already and you arent seeing a ton of power I would look at other areas instead of hitting it with a bigger hammer. Like what are your IAT's? Is your intercooler big enough? I just dont think more boost is always the answer. You may also need to be more specific about your combo for the real experts here.
Old Jan 8, 2004 | 06:21 PM
Birdie2000's Avatar
The motor is getting refreshed over the winter, very serious work is being done to the heads and also getting a very serious cam. I know the intercooler isn't helping me, I don't have one! I know this is killing the power somewhat, but the car didn't come with one. I'm going to experiment with water/alky injection until the funds allow for a full blown air/water intercooler setup, in addition to running race gas. Either way, I'm not really concerned about the diagnosing the current situation. I'm mainly curious how I should pulley my blower so that it's putting out as much air as possible when the time comes, and what I'm really curious about is how to properly read/use the compressor maps.
And yes, I know the drivetrain isn't excellent for getting the power to the ground, but the dyno numbers I think are low were made when a M6 was in the car. And I have a feeling my 1/4 performance is no where near what it should be for the amount of stuff in my engine.
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
