Got a little smoke from under the hood...
Old Jan 6, 2004 | 02:28 AM
96 WS6's Avatar
It is only coming out of the left side where the blower is. I think it's the seals on the blower because it only happens sometimes and my drain hose has a slight dip in it. Next oil change I'm going to shorten the drain hose so it doesn't dip but are my blower seals shot??? How do I get new ones? Send to vortech?
Whenever I try to check it out when the smoke comes out it stops by the time I get under the hood. Could oil leak past the seals and burn on the blower or would it leak into the intake tube. What else could it be?
Is that even my problem? My car smells like burnt something (possibly oil) when I drive sometimes and it's getting annoying. I put a ton of time into the car for it to stink when I drive it.
Old Jan 6, 2004 | 04:02 PM
JAY'S 91Z's Avatar
My experience has been that if there is something mechanically wrong with your charger you won't make boost and as far as the smoke goes, I assume by what you describe that you have an oil line to your pan. If you have a small leak somewhere in that line, it may not show up at idle. The charger requires more oil under boost, but it will only make boost under a load. Best way to check for the leak is on the dyno.
Old Jan 6, 2004 | 11:07 PM
96 WS6's Avatar
I just had a thought... I forgot to use teflon tape on the fitting for the alcohol line. Hmm I will try that too.
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
blaze309
Sep 8, 2015 05:27 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
alphaauto
Jul 26, 2015 04:40 PM
