rear end noise
Old Jan 3, 2004 | 04:31 PM
95lt1&99ls1's Avatar
Exclamation rear end noise
my rear end is making a noise that sounds like tire noise. When the rear tires are lifted off the ground it still makes the same noise. I changes the front pinon bearing and the noise is still the same....
Anybody have any ideas????
Old Jan 3, 2004 | 09:13 PM
wrencher's Avatar
Did you do both bearings & the crush sleeve?
Did you check te backlash & pinion depth?
Did you check the contact pattern?
Old Jan 4, 2004 | 02:37 PM
cals400ex's Avatar
i am not sure about the ls1's, but some of the lt1's do that when you don't use the gm friction modifier in the rear.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
