Autocross and Road Racing Technique There is more to life than a straight line
dumb question phb install
Old Dec 18, 2003 | 03:44 PM
RedPhenx's Avatar
I got the lca and lca reloc brackets installed, but the PHB from Dynamic Motorsports does not seem to fit, the space seems to large when i put the new one in compared to the old one, the brace or whatever it is wont fit. do I use stock bushings? anyone know? sorry if this doesnt make sense, but it's the only wayt I can explain it.
Old Dec 18, 2003 | 07:49 PM
TA Dreaming's Avatar
which end are you referring to. the axel end or the body end? what type of bar do you have one with poly bushings at both ends or one with a rod end on it? if its a rod/poly ended bar the poly end goes on the body the rod ends goes on the axel. Trey
Old Dec 18, 2003 | 08:57 PM
mitchntx's Avatar
And if it's just a small amount of play, then the bolt and nut should squeeze it down just fine.
Old Dec 18, 2003 | 10:18 PM
RedPhenx's Avatar
ok, thanks for the replies, sorry if I didn't make too much sense in the first post, the problem is the company didnt send the [poly bushings that connect on either side of the bolt holes. They are sending them out, that is why the width was too small.
87Aerocoupe
Jan 10, 2015 07:27 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
