blow-down tube for street use
Old Dec 16, 2003 | 10:56 PM
JJJ93z's Avatar
is it a good idea to get a blow-down tube , even if you have a purge? the bottle would be open when crusing on the street , thats why i ask. also the -8an safety fittin g taht NOS sells replaces the pressure relief cap , then the blow down tube connects to that? thanks for the help!
Old Dec 17, 2003 | 03:38 PM
If you have the bottle inside the car, its a good idea to vent the safety relief disc to the outside of the passenger compartment. In the VERY remote event that the pressure relief disc ruptured, it would dump an opaque cloud of gas that could suffocate you, and prevent you from seeing out of the car.
Yes... you put the -8AN fitting in place of the normal disc fitting on the bottle valve assembly, then attach the blowdown tube, or a braided hose to that.
Braided vent connection
Old Dec 17, 2003 | 06:23 PM
JJJ93z's Avatar
thanks for the great info and pic! also where did u run your n20 lines underneath your car?with the fuel lines? thanks agian
Old Dec 17, 2003 | 06:26 PM
LS1 Bird's Avatar
I wouldn't run without that tube. Hopefully you'll never need it, but that one time you do .....
Mike M
Old Dec 17, 2003 | 08:43 PM
JJJ93z's Avatar
nice dual purge ls1 bird, do u have a better picture of the t connection and the hoses used on the cowl, or i you did the work yourself, could you tell me how it was done?
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
Queens94z28
Nov 20, 2014 06:03 PM
