torque converter
Old Dec 15, 2003 | 03:52 PM
brassballs's Avatar
Cool torque converter
hello guys and gals
can you guys tell me what torque converter in the TCI brand is a direct replacement for my 97z 28. i would like to have something in the 2800 stall range. I am running 150shot,few mods:
Old Dec 15, 2003 | 05:00 PM
WrecklessZ's Avatar
I think B&M has a Nirtous conveter check them out.
Old Dec 15, 2003 | 08:13 PM
Pro Built Automatics's Avatar
Stay away from B&M, unless you like potential problems, TCI is a little better. Yank, Vigilante, are the best. Edge and Midwest are good from what I hear. Except for GER (out of busines from what I have heard), the B&M has the highest comeback ratio on torque converters out there. Remember when the TC goes, so does the transmission in most cases.
Old Dec 16, 2003 | 12:11 AM
S.J.S.'s Avatar
What other mods do you have??? Call which ever company and give them your specs and they can tell ya what size you should run. I'm with the guy before me. I would go with TCI, Yank or Vigilante.
Old Dec 16, 2003 | 12:35 PM
boomcase's Avatar
TCI streetfighter is the one your looking for.
Old Dec 16, 2003 | 03:12 PM
brassballs's Avatar
IS THE TCI A 3000 STALL OR 2800
Old Dec 17, 2003 | 07:37 AM
boomcase's Avatar
Its rated at 2800, but just like most converter they will stall higher depending on your mods/hp
Old Dec 17, 2003 | 03:21 PM
brassballs's Avatar
BOOMCASE,IS THIS A DIRECT BOLT ON TO FLYWHEEL/WILL I HAVE TO MAKE ANY CHANGES , NEW BOLTS
Old Dec 18, 2003 | 01:49 AM
revtime's Avatar
I put new bolts in, it is cheap insurance and yes it should bolt right up.
Make sure you get the converter to engage properly with the front pump.
Took me a couple of tries to get it right, I also poured 2 quarts of fluid into the converter before installing it on the tranny.
Old Dec 18, 2003 | 08:58 AM
boomcase's Avatar
As far as I know all torque converters are a direct boltin, but you might have to drill the flywheel holes (3) alittle bigger depending on the size converter bolts they give you, some companies use bigger than stock bolts. No big deal thou.
Old Dec 18, 2003 | 12:24 PM
brassballs's Avatar
THANKS FOR YOUR REPLY,YOU FELLAS HAVE BEEN A REAL HELP.NOW,I HAVE 273 GEARS DO I NEED TO GO HIGHER?
Old Dec 18, 2003 | 02:31 PM
boomcase's Avatar
No you do not need a better gear , The converter will work great with 273 and nitrous . Just do the converter first and if your not happy , spring for some gears, 342s are sweet.
dboone2172
May 16, 2015 07:45 PM
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
StansZ28
Feb 19, 2015 07:39 AM
veryslowfbody
Aug 22, 2002 04:31 PM
