Header install..
Old Dec 14, 2003 | 01:28 PM
k9ulan's Avatar
Header install..
I am fixin to install my new Pacesetter headers and Y-pipe.
Is there an install guide somewhere that also lists the tools ill need..or just one of the above.. I already searched with no luck..thanks in advance
02 Z28 A4
Old Dec 14, 2003 | 07:15 PM
nikkev's Avatar
http://drs.yahoo.com/S=2766679/K=ls1...icles/mac.html
Those are MAC mid-lengths,but the install process should be the same.Good luck...
Kevin
Old Dec 19, 2003 | 11:23 PM
blackztpi's Avatar
undo the motor mounts and jack the motor up for clearance. from there, it's all luck for how long it takes you
Old Dec 20, 2003 | 07:42 PM
mr_muff's Avatar
why would you do that? you don't need to, that would just take more effort and more time.
Old Dec 21, 2003 | 12:04 AM
DarkblueTA's Avatar
I put my Pacesetters on a few months ago.
1. Have a lift, it will make your job so much easier
2. if you have access to a torch, just torch the stock manifold/ypipe connecting bolts off
3. 10mm 1/4 socket and rachet are your best friends, especially the last manifold bolt on the passenger side.
Passenger side header slides right up in..no problems
Driver side header, I unhooked my steering column, moved it out of the way and put the header in...hooked the steering column back up and away I went. 5-7 minute job.
If you are planning on doing this job on jack/jackstands...good luck...I did one set of headers for my friend that way and it totally sucked.
If you're in/near Lancaster PA and need help, PM me...hope all is well and good luck with your install!
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
