Seems like my car is running a little hot
Old Aug 19, 2002 | 08:11 PM
BigZ28's Avatar
Post Seems like my car is running a little hot
Coming home from work today, it seemed like my car was running a little warm. I was on 635(Dallas, doing ~60+MPH) and my temp was at about 210*. Is that a little high or what. When I finally ran into traffic and slowed down, I turned the a/c off and flipped the fan switch on. It only went down to about 200*. What kind of temp is everyone else seeing?
Thanks for the input
Brian
Hunter Green 94 Z28 A4, K&N Induction, Ported MAF,
Yank 3200 Stall Converter, Dynomax Exhaust , Hooker Shorties, Cutout
Old Aug 19, 2002 | 09:24 PM
AHARTZ28's Avatar
Post
thats actually normal
1994 Z28 A4
383 scat 9000 series crank, eagle rods, wiseco 12:1 pistons CC306,TCI Streetfighter,HOOKER LT's,Meziere H20 pump,LT1 Edit,95+ opti
1/4:11.89
11.64 corrected
MPH:115.23
1/8th:7.6x
60':1.77
The Beastdual exhuast
Old Aug 20, 2002 | 03:54 AM
texlurch's Avatar
Post
Is that what your car has been running at, or is it higher? If the temp went up more than normal, I would make sure your fans are running, and you didn't suck some paper up in front of the radiator. Just unbolt the top retainer across the top of the radiator, lean it back and check the front of it.
Texlurch - 68 Camaro-LT1 w/Hot Cam, TT & TIC coming soon!
" a little spray never hurt anyone, spank you very much!"
http://camaroz28.cardomain.com/id/texlurch
[This message has been edited by texlurch (edited August 20, 2002).]
Old Aug 20, 2002 | 04:19 PM
95ChameleonTA's Avatar
Post
Well Living here in TX I have gotten the 160 thermo and my temp needle barely moves! Oh yeah I also have the CSI Elec Water pump. works very well
Scott Endersby
95 Chameleon Trans Am M6
306cam, ported heads flow #255/193, 30lb Ford Motorsports injectors, hooker LTs, 2.5in y-pipe,SLP Loudmouth, CSI WP, 58mm BBK TB, 1.6 Pro-Magnum RRs, 10308-1 Spring, Cloyes Double Timing chain, CC "R" lifters, 160 Thermostat, Hurst, MAF, K&N CAI, Eibach springs, Lou's short stick, LGM Abj. Pandhard, MSD coil, Nitto DRs, TB bypass, LGM adj. lower control arms, LGM STB, LT1 Edit
1/4 mile and dyno soon
homepage (old info)www.95chameleonta.cz28.com
pics Yahoo photos
Hooker LTs + 2.5" ypipe + Loudmouth= Cop Quote "Ungodly Loud!"
July 1, added Bullet muffler.
Old Aug 20, 2002 | 04:25 PM
Post
Scott Endersby
pics Yahoo photos
Old Aug 20, 2002 | 05:53 PM
BigZ28's Avatar
Post
Running at this temp is not normal for my car. It has never ran this hot just cruising down the highway before.
Texlurch- I'll check it out and see.
Thanks for the replies guys
Brian
Old Aug 20, 2002 | 08:12 PM
bad95z28's Avatar
Post
double check and make sure your fans are working, theres no trash anywhere in the way, and all of the plastic peices underneath are still connected right.
Black 94Z A4 t-tops
324rwhp/316rwtq (before new mods and better tuning)
The Z
Britbilly
Jan 7, 2015 08:49 PM
Collector Car
Dec 17, 2014 01:12 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
GigaMp3z
Feb 20, 2003 02:57 PM
