tranny prob, please help
Old Dec 9, 2003 | 03:55 PM
Z284LIFE's Avatar
Unhappy tranny prob, please help
I've got a 94Z28, 4l60e tranny and about 136,000km on the engine. The tranny was rebuilt around 100,000km.
Overall the car is great. But if I'm cruisin on the highway around 120km/h or so and hit it to WOT, the tranny downshifts to 2nd (I believe it's second gear, I have 2.73 gear ratio), hits redline and pauses for a few seconds before finally finding 3rd gear. Sometimes I have to let of the gas for it to shift into 3rd.
Any ideas why this is happening? What would cause the tranny to lock up in 2nd like that when it hits redline??
Old Dec 10, 2003 | 11:50 AM
Z284LIFE's Avatar
anyone???
Old Dec 10, 2003 | 12:35 PM
Red_94Formula's Avatar
sounds like a bad rebuild. it would need to be done over to fix that.
Old Dec 10, 2003 | 12:49 PM
Sweetred95ta's Avatar
Redline?? Is your car stock because if so it would hit the rev-limiter before it redlines. Do you have stock tires and wheels, cuz maybe your shift pts. are off. And what else does it do, it just sits for a second at top of 2nd and then shifts??
Benji
Old Dec 10, 2003 | 01:06 PM
FastZinTennessee's Avatar
If the other shifts are ok, but on the 2-3 shift the gear winds out and hits the limiter before third gear engages then that 2-3 clutches are getting weak. Mine was doing this with mobil 1 and when I switched to Valvoline Maxxlife it went away. It only did it every once in a while. Then when I put a shift kit in it, well, it'll snap your neck, no hitting the limiter What kind of fluid do you run?
Old Dec 10, 2003 | 01:30 PM
Z284LIFE's Avatar
Sorry guys I forgot to mention that I had my PCM reprogrammed by PCM4less, but as I recall, this problem was happening under the stock programming as well.
Basically when I gun it while on the highway, it'll drop down to 2nd, accelerate till around 130 or 140 where it reaches the end of 2nd, then it'll just bounce of the limiter for a few seconds, at which point I will ease of the gas to allow the tranny to shift. It's a real pain in the ***.
In response to FastZ,
I usually have used just regular oil that the dealership puts in, but I recently switched over to Mobil1 high mileage. Do you think I should try the Maxxlife? How is it different?
Old Dec 10, 2003 | 02:11 PM
Mine was acting funny before too. Would hit the limiter before it shifted, and it turned out to be a cracked piston in the tranny. It was loosing pressure and it wasnt able to shift. But it drove fine unless it was at WOT. Good luck.
Benji
Old Dec 10, 2003 | 04:05 PM
The mobil 1 ATF is slicker and thinner and the tranny is more prone to slip with it than a heavier fluid like maxxlife.
Old Dec 10, 2003 | 05:35 PM
Brent94Z's Avatar
Super Moderator
Moving to the Drivetrain forum...
Old Dec 10, 2003 | 06:28 PM
Lisa33's Avatar
My friends car had the same problem when he had low oil level in the tranny. (he didnt check the oil level the right way) so when we added oil to the right level the problem was solved.
Old Dec 11, 2003 | 12:19 AM
90rocz's Avatar
Not sure how they control the throttle/valving on the "E" models but it isn't right, if it continues it will definitely shorten the trans's life.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
