Need help with Tps Switch
Old Dec 6, 2003 | 06:50 PM
96b4ccamaro's Avatar
I was going to hook up a TPS switch as a saftey so I only actvate N2O at WOT and i wondering if the NX TPS sending switch (NX-15961) would work on lt-1's. On their web site they say it activates at 4.0 volts or higher. is that what the stock TPS is set at for WOT.
Old Dec 7, 2003 | 11:37 AM
Wild1's Avatar
The stock TPS gets a 5V reference signal from the PCM. It will fluxuate between 0.2-4.9 depending on throttle position.
0.2 +/- is at idle
4.9ish is WOT
I haven't used the NX TPS, but I am looking very hard at the Maximizer which uses that switch.
Either way, remember to solder your connection then seal with heat shrink wrap... any crimping with butt connectors or taps will eventually oxidize and affect readings by adding resistance.
IndyZman
Oct 22, 2015 02:17 PM
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
tdigger9899
Sep 7, 2015 10:56 AM
