Is a Switched Supercharger Possible?
Old Dec 5, 2003 | 05:51 PM
Pandamonkey's Avatar
Would it be possible to have a supercharger that operates on a switch?
What if a person were to rig some sort of clutch assembly onto the pulley of the SC that is operated electronically off of a switch on the dash?
You could have stock power when you wanted it and then flick a switch for some added ummph when needed.
It would be like unlimited nitrous.
I suppose most of us would have it "on" all the time anyhow.
Old Dec 5, 2003 | 05:53 PM
Knowklew's Avatar
why bother?
Old Dec 5, 2003 | 05:54 PM
JoeliusZ28's Avatar
Originally posted by Knowklew
why bother?
probably so the engine lasts a little longer, just a guess.
Old Dec 5, 2003 | 06:01 PM
CtRw's Avatar
Uh, if you have forged internals the engine will last just as long, if not longer, than a regular non-boosted engine.
Old Dec 5, 2003 | 06:22 PM
Helfire's Avatar
Boost doesnt come on until full throttle so, umm.... dont floor it.
Old Dec 5, 2003 | 06:31 PM
DWray's Avatar
Old Dec 5, 2003 | 06:37 PM
mike95z28
Guest
Posts: n/a
You'd have to have some kind of clutch-engagement like how the AC works. As you turn that switch on, the timing/fuel would have to be altered to take into account the blower. This added compression would have to be taken into account as well. All in all it's a bad idea.
Old Dec 5, 2003 | 07:42 PM
stars1010's Avatar
The computer if properly programmed could alter timing/fuel. I think its a neat idea. I’m sure it could be done and possible advantage could b found, I'm sure. Good thinking Pandamonkey.
Old Dec 5, 2003 | 08:00 PM
Sephiroth's Avatar
BWAHAHAHAHAHA!!!!!!!!
You rule...............
Old Dec 5, 2003 | 08:04 PM
JoshGuitar's Avatar
why bother?
just like the "valet switch" some cars have, that cut power and won't let you exceed 2500 RPM or so
Old Dec 5, 2003 | 08:48 PM
2MCHPSI's Avatar
Mad Max had one.
Old Dec 6, 2003 | 12:07 AM
lil_mikey69's Avatar
Ive never heard of that. If I ever get a nice enough car, and actually had money to go out thats something Id look into!
Old Dec 6, 2003 | 12:14 AM
BigBlockChevy's Avatar
What if you had something like vtec, where the blower pulley expands/contracts? that would be sweet, though the belt tension would be the problem
Old Dec 6, 2003 | 12:16 AM
yeah, its actually a valet key, so when that key is in the ignition, it won't go past a certain amount of throttle percent, speed, or rpm. The only two i know of off the top of my head are a ZR1, and my moms old acura TL. I'm sure many companies have it though
Old Dec 6, 2003 | 07:24 AM
thehunter's Avatar
If the impeller isn't spinning and compressing the air, how is air getting by?
Mike
