396 stroker assembly and 4 bolt main block for sale
Old Dec 4, 2003 | 05:28 AM
LT1RX7's Avatar
pistons are SRP part# 144995
Rods are Eagle part# 6000B3D
Crank is Eagle part# 435338756000
Pistons have a 5cc dish which will yield 12.2:1 CR with 58cc heads, 11.4:1 with 64cc heads. Rods are 6" H-beam 4340 forged steel. Crank has a 3.875" stroke and is also 4340 forged steel.
This setup cost right about $1600
The block is an LT1 from a 94 Z28. It has been bored .030" over using torque plates. It also has 4 bolt splayed main caps. It has been align honed and ready for parts to be bolted up. I had $800 in labor alone for all the work done to it.
I want to sell this as a package so email me some offers or someone let me know how much I should sell these for. It is basically a whole shortblock. I also have other parts like crank hub, harmonic balancer, rear main seal, timing cover, oil pan
Old Dec 4, 2003 | 04:28 PM
JohnsSS's Avatar
are the parts above new? forged? block included?
Old Dec 4, 2003 | 08:25 PM
StangStomper's Avatar
where are you located?
Old Dec 4, 2003 | 09:39 PM
LT1RX7's Avatar
here is my auction link
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2446870219
Old Dec 5, 2003 | 01:59 AM
JohnsSS's Avatar
would this application be ok in a daily driver, still mostly streetable???
I guess kind of depends on the cam. assuming nothing crazy on the cam is it a daily driver setup?
Old Dec 5, 2003 | 03:20 AM
LT1RX7's Avatar
this kit I think is perfectly streetable with the right cam. Does someone else want to shed some light this way? CR i skinda high but people have been running even higher CR on pump gas
Old Dec 5, 2003 | 11:37 AM
JohnsSS's Avatar
The Comp ratio is my main concern. I thought the most that should be run on pump gas in an lt1 was 11.1:1 or something similar, but i've been very wrong before.
also I have lt4 heads, but don't know the size of the CC, i'm guessing it's standard on all lt4 heads, is it? do you or anyone out there know what it is? Valve size is 2.02 in and 1.585
Old Dec 5, 2003 | 03:43 PM
LT1RX7's Avatar
I've seen LT1's run higher than 12:1 ion pump gas. The LT4 heads are a good start for building this 396. In fact I have a set of AFR valves if you are interested. I also have a solid roller cam made by Cam Motion
Old Dec 6, 2003 | 03:20 AM
JohnsSS's Avatar
AFR valves?? what are they, and what are the specs on the solid roller cam, I think my lt4 cam is a roller rocker, would I have to change other things?? What are the cam specs that you have, how much for the both.
Old Dec 6, 2003 | 05:10 AM
LT1RX7's Avatar
here are the cam specs
intake exhaust
duration 245.3 245.6
valve lift .612 .613
lobe lift .383 .383
lobe seperation 112
The valves are 2.08/1.6. Both are brand new never installed
I want $350 for valves and cam, that's about the price for just the cam so you'll be getting the valves for free
Old Dec 7, 2003 | 07:56 PM
greatwhitez's Avatar
i am really interested in the motor, i have been emailing you previously, im MOBOGRND13, and blackiroc3 on ebay.. email me i'll take the engine, we can work out something
Old Dec 8, 2003 | 01:08 AM
StreamlineZ28's Avatar
just a question. what kind off compression height are the pistons to be running 6 inch rods? doesnt sound like the best idea IMO
Old Dec 8, 2003 | 10:35 AM
JohnsSS's Avatar
what would the cr be on a set of lt4 heads with a 54.4cc? thanks
Old Dec 8, 2003 | 02:17 PM
RacerTim's Avatar
Way too much is your answer.
Old Dec 8, 2003 | 04:47 PM
onebad96T/A's Avatar
What i have been looking for sent you a PM
HectorM52
Jul 30, 2017 11:46 AM
Sergio
Jan 27, 2016 04:27 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
97 RedSS
Jun 10, 2003 07:58 PM
