Autocross and Road Racing Technique There is more to life than a straight line
Weld in SLP bolt in SFC? Why?
Old Dec 2, 2003 | 10:46 AM
v7guy's Avatar
I see it reccomended in here fairly frequently to get bolt in SLP subframes and then weld them in, why is this?
Also how would you go about welding them? At the plates? athe plates and bolts?
how close do they sit to the rockers? would you need to C channel them to weld the to the rockers or can you just weld the straight over by bending the tab?
Old Dec 2, 2003 | 01:02 PM
TxAgZ28's Avatar
Welding in SFC's makes them much stronger. Instead of the load being applied at the bolted points, it is applied across the entire welded area.
Old Dec 4, 2003 | 08:55 AM
v7guy's Avatar
I'm aware of why you weld them, but I question why it's reccomended to get the bolt ons and weld themin rather than just get the cheaper weld ins and weld them in
Old Dec 4, 2003 | 10:45 PM
TxAgZ28's Avatar
Heh, my bad
Sounds kind of dumb to get the bolt-ins and then weld them. Once you weld them the bolts become negligible. I'd say get the weld-ins and go. Can't think of any reason to buy the others, unless there is a difference other than the bolt holes? Maybe the bolt-ins are thicker?
Old Dec 5, 2003 | 03:19 AM
RS Dragster's Avatar
Basically it's because some people put the bolt-ins in, let it be for a while to see if they like it. Problem is, some people think it's "good enough" and don't weld them in, and over time they get a little loose.
But yeah, basically so they have they choice, that's why they do it. It's just as good to get weld-ins.
Old Dec 6, 2003 | 07:02 PM
Rice Eater 316's Avatar
The SLP weld in's come unpainted/unfinished and have to be painted or they'll rust. The bolt-on's come powdercoated already.
CLEAN
25
Aug 20, 2018 01:31 PM
HarleyZ28
Oct 5, 2015 06:23 AM
maybe2fast
Mar 16, 2015 09:45 AM
jakeSS
Jul 22, 2002 06:54 PM
