what is this table used for ( in tuner cat)
Old Nov 29, 2003 | 09:35 AM
Fbody1's Avatar
the table is low pulsewidth injector offset adder v.s bpw , don't know what this table is for? and do I need to adj it for my svo 24# inj ? it is at the stock setting now
Old Nov 30, 2003 | 01:27 PM
PoorMan's Avatar
I don't really know. Never messed with that table. I'll take a guess though. The BWP is the injector base pulse width in micro secs. Why micro seconds? I don't know. I have only seen people talk milliseconds. The "adder" is the amount of time to add to that perticular base time when doing a correction for the next go around. The bases are 10ths of a millisec and we all know that the total pulse witdh is around 2 or 18 millisecs depending on load. Most of the "adders" are above 1 millisecond though so this table must be very important. How this ties would be nice to know.
Jeff D.
Old Nov 30, 2003 | 05:18 PM
Fbody1's Avatar
someone has to know what this table is for !
Old Dec 1, 2003 | 09:20 PM
95Blackhawk's Avatar
The table is for you to leave alone.
Seriously, if you don't know, don't mess with it. Never heard of anyone doing so. If you injectors need to be adjusted, they are to be adjusted in the Constants.
Ben
Old Dec 1, 2003 | 09:29 PM
brain's Avatar
Not to hijack a thread, but I was curious about a constant...Its SPARK REFERENCE ANGLE. I haven't found any info about it, but was curious. Could this be a compensator for installing a cam advanced or retarded? Its been 0 in every map I've looked at, so I'm not too sure. I know the Speedpro has a crank reference angle, which if I remember right is 6 in an LT1, and we had it at 50 on a mustang my friend has. Anyone???
Old Dec 3, 2003 | 04:53 PM
Fbody1's Avatar
never seen that table in tuner cat?
Old Dec 3, 2003 | 08:46 PM
brain's Avatar
Its not a table, its under the constants table. Its almost at the very end. Not sure what it does, but I may play with it sometime soon.
Old Dec 5, 2003 | 06:53 AM
PoorMan's Avatar
Fbody1..I pm'ed you a question about another post. Anyway, I went on a mission and this is all I found anyone had said about it. I do not know how true/false this is either.
"This table adds a bit of injector opening time to correct for the time it takes to fully open the injector. You only need to adjust this if you change injectors (for example, the SVO injectors take longer to open, so you'd increase the values slightly to compensate for this)."
Jeff D.
Old Dec 6, 2003 | 09:56 AM
raul.garcia's Avatar
Injectors
I don't see that table in Tunercat my ecm is 1227165 and my bin is ARAP $6e (may not be used for MAF.)
The time it takes from receiving the pulse and the injector opening is called, "Injector dead time," which varies with injector type. This is highly dependent on battery voltage. The injector Pulse Width correction vs battery voltage is in micro-seconds and is as high as 5.7milli-sec at 6 volts, but I don't think that includes the dead time offset. Haven't found the dead time for the Accel 30# injectors I have. I'll call tech support on Monday and edit this reply.
GREEN3112
Feb 10, 2019 09:19 PM
n2oblkz
Oct 12, 2015 01:53 AM
fift5
11
Oct 1, 2015 10:31 AM
Ks0209
Oct 1, 2015 07:32 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
