help me with shopping list, building turbo LT1
Old Nov 8, 2003 | 10:39 PM
LT1RX7's Avatar
OK, I'm building a turbo kit for my RX7 with an LT1 and need someone to tell me what parts to buy. Here are the parts I'm buying, just need to know who to buy it from and what brand/kind
Turbo (TO4B?)
injectors
wastegate
header flange
BOV
rockers
valve springs
retainers
pushrods
lifters
cam
I really need to know if the TO4B is big enough to run like 6-8psi. I don't want to go overbored just yet. Also need to know what size injectors to get for 800hp+ (for later).
Old Nov 9, 2003 | 12:03 AM
1994B4C's Avatar
I would say a TO4 would be big enough for 6-8psi on an LT1, but will not make your 800HP goals for later. Just build it for 800HP now if thats what you know you will eventually want. You can always open up the waste gate and get the boost down.
I will make a few suggestions for the brand of each part.
Turbo, I would get the common 76mm from turbonetics, precision, or innovative, those are all really popular.
Injectors-seimans deka, waste gate- turbonetics racegate or their new really big one, For all the valve train parts you can get comp cams chromemoly parts they won't break the bank and are pretty nice parts, and I would get a recommendation from Cam Motion for the cam.
Old Nov 9, 2003 | 01:13 AM
LT1RX7's Avatar
I think I'm going to stick with a smaller turbo for now so I won't get huge lag and only end up with 6psi. I'll probably end up with a T88 later. For the wastegate, can I get a 38mm? I realize it is a small gate but I am also using a pretty small turbo.
Injectors, where can I find seimans?
Old Nov 9, 2003 | 02:32 PM
Camaro37's Avatar
Forgive my ignorance but if you had a small turbo wouldn't you want a larger wastegate? A small turbo will allow less exhaust through compared to a larger turbo meaning alot of the exhaust would need to escape out the wastegate, therefore you would want a larger WG with a smaller turbo, right?
Old Nov 9, 2003 | 02:41 PM
Chris B's Avatar
Re: help me with shopping list, building turbo LT1
Turbo (TO4B?)
I'd go with a T-76 GTQ trim
injectors
Siemens-Deka 72-83lb/hr injectors, low impedance
wastegate
Tial, 46mm
header flange
Don't know off the top of my head - you could just get some 1/2" plate and have them plasma cut.
BOV
Tial
rockers
Comp cams pro-magnum
valve springs
depends on cam, rpm, etc.
retainers
Titanium
pushrods
chrome moly
lifters
comp "r"
cam
depends on your hp/rpm goals. Best bet is to talk to someone who has experience camming turbo setups. Will also be highly dependant on what turbo you end up, your exhaust setup, and what boost levels you want.
Chris
Old Nov 9, 2003 | 10:23 PM
LT1RX7's Avatar
actually a smaller turbo would be fine with a small wastegate. With a small turbo a big engine would suck up more air. This makes the turbo work harder to build boost. If the turbo works harder, the wastegate can be smaller
Old Nov 9, 2003 | 10:34 PM
LT1RX7's Avatar
Re: Re: help me with shopping list, building turbo LT1
Originally posted by Chris B
Turbo (TO4B?)
injectors
wastegate
Tial, 46mm
header flange
BOV
Tial
rockers
valve springs
retainers
Titanium
pushrods
chrome moly
lifters
comp "r"
cam
Chris
Just ordered a bunch of parts
TO4B turbo
Tial 38mm wastegate with .3bar spring
1.7 forged rockers
Comp dual valve springs
Comp Ti retainers
7/16" rocker studs
Comp chromemoly pushrods
Comp Pro Magnum lifters
Comp 224/236 114 cam
pushrod guideplates
Areomotive fpr
1/2" header/turbo flanges
Apexi blow off valve
Lucas 42# injectors
All in one day Can wait to start building this thing now. I wonder what I'm going to do for the heads now? Off to another post
Old Nov 9, 2003 | 10:36 PM
1994B4C's Avatar
What made you buy that cam?
Old Nov 9, 2003 | 10:41 PM
Chris B's Avatar
Yeah, not the cam I would have gone with for a turbo motor...
Chris
Old Nov 10, 2003 | 09:41 AM
got_hp?'s Avatar
yeah, im pretty sure thats a blower cam......not great for turbos.
Old Nov 10, 2003 | 12:04 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
as others said, that is a blower cam, it will work horribly with your setup.
1.7 rockers, very bad choice. valvetrain geometry and just plain lift is going to be too high.
you really should listen to people...
Old Nov 10, 2003 | 12:31 PM
LT1RX7's Avatar
what cam should I have gone with then? I figured a cam for forced induction should have worked good for what I was building. I had no idea blower cam is different than turbo cam
Old Nov 10, 2003 | 12:44 PM
got_hp?'s Avatar
blower cam is usually higher exhaust duration than intake, like 224/236
turbo cam is usually equal or greater intake duration, like 220/220 or 230/220........the smaller exhaust duration creates a higher exhaust velocity, spooling the turbo better...
atleast thats my understanding, im sure someone can give a better answer.
Old Nov 10, 2003 | 03:06 PM
Thats why you should listen when people give advice
Old Nov 10, 2003 | 03:29 PM
Secret Formula's Avatar
The wastegate size depends on how much boost you are running, and engine size. Running 6 pounds, the wastegate needs to get rid of more exhaust gas, than if you were running 30 pounds. The Tial 38mm should be fine, but if it doesn't keep the boost down, then just get a bigger one.
What are the specs on that turbo? Why did you choose that? I don't think a TO4B will do well at low boost levels.
