Reliability of a SC LT1
Old Nov 4, 2003 | 08:14 PM
tend2609's Avatar
What Super Charger Kits can be put on an LT1 and not affect its reliabilty, I think 8 PSI is max what do u guys think?
Here are some kits i was thinking about
ProCharger P600B Kit w/ 2-Core Intercooler (if i upgraded to the P1SC H.O. would that bring up PSI? or is it just a better unit then the P600B - $3,099
Vortech Supercharger Kit with V-1 S-Trim - $3,399
Vortech Supercharger Kit w/ V-2 SQ S-Trim - $3,399
What is the difference between the two Vortech Systems?
Old Nov 4, 2003 | 09:45 PM
94SLUG's Avatar
You should search this topic. Boost and high compression is not safe. A piston will go. If your ready for a rebuild go for it. 600b is worthless IMO, and both vortech kits are quality(no intercooler). You need to give some more info on what your looking for, and how much $$$$$$ your willing to spend. There is a lot more than just the kit to buy.
Bill
Old Nov 5, 2003 | 03:31 AM
talos's Avatar
Re: Reliability of a SC LT1
one is an SQ...
SQ = Super Quiet
the s-trim is quite a loud blower
Old Nov 5, 2003 | 09:02 PM
lethal93ta's Avatar
p600b is worthless thats what I have I went from a 13.7 @ 102 to a 12.26@ 115 with just the blower once I put gears and a stall in my car ill see 11s for sure on a stock motor, the blower has been on for two years now and no problems with it, I just wish my trans and rear could take as much abuse as the motor is.
Old Nov 6, 2003 | 08:04 PM
EDS Z28's Avatar
The P600B is not worthless my friend. I have had mine on since 1995 and it is still running strong. It is a bit loud, like the s-trim.
The kit to get would be the P1SC with the twin intercoolers. The twins fit real nice. The vortech is really good too, but I never cared for their water to air intercooler.
You can run the blower without doing anything to the shortblock, but it will break eventually, the LT1 pistons/rings were never designed for forced induction. The factory would have put forged pistons in and probably a forged crank if their was a blower on this engine.
Old Nov 6, 2003 | 08:30 PM
steve10358's Avatar
3rd Gen Tech Moderator
Here's the deal- don't let anyone fool ya, it's lack of tuning and greed that kill an LT1. With the right tuning, and common sense, 6psi can last forever.
I make 11 second power, with a 12 second chassis. One more part (torque converter) and I will be in the 11's on 6psi w/ a 100% stock motor and my P1. I have a low 12 second car RIGHT NOW. All it took was the right parts and a good blower.
Get the P1. It made me at least 170rwhp more, and is bigger than the s-trim, not to mention intercooled.
To make it live? Easy-
1. Ditch the FMU for a 36# injector
2. Get to a dyno and tune it with a wide band with someone that actually has the experience.
Old Nov 6, 2003 | 08:35 PM
Chris B's Avatar
If you are going to run the blower on a stock bottom end I would make sure you can afford to do a rebuilt (both with regards to money and downtime) - sure, it may last awhile with good tuning, etc. - but then again it may not. It isn't something I would want to gamble on.
As for which to get, my personal preference would be for a vortech kit and add a spearco intercooler.
Chris
Old Nov 6, 2003 | 08:40 PM
lethal93ta's Avatar
the biggest thing you have to watch for is knock that will kill a motor, I use a scan tool to watch for any on my car, im still on stock programing sence I have a 93 its really hard to get someone to work with you on a chip, I have PCM for less on my side now I just have to get off my butt and get a data log off datamaster for them of my car now and send it to them and work from there. im hoping for a mid 11 second pass next year once I get gears/stall and some programing I should easily see that sence right now my car is a dog off the line only 2.0 60 foots.
Old Nov 7, 2003 | 07:14 AM
rskrause's Avatar
Moderator
These engines were (obviously) not designed for boost. As has been mentioned, the pistons are the weak point. I would NOT assume 6lbs is "safe", but it's a lot safer than it would be with more boost.
The thing is, 6lbs doesn't really net much hp on an LT1. Obviously, if you also have good heads, a big cam, etc. it will make good power. But most people interested in "just" 6lbs of boost want a bolt-on situation. These typically don't gain more than 75rwhp or a bit more with 6psi. A good exhaust system really helps out a boosted car, BTW. Add headers and a good cat back and you will gain an additonal 30-40rwhp. But if you think your car is gonna be the hottest thing in the neighborhood with just a 6psi blower, think again! 6lbs of boost on an LS1 is another matter, those things rock with a little boost.
Bottom line, if you are interested in "reliability", you really shouldn't boost a stock short block. You might get lucky, but no matter what you are not going to achieve OEM engine longevity.
Rich Krause
Old Nov 8, 2003 | 02:29 AM
CJ's Avatar
CJ
Both kits have its advantages. Procharger with the intercooler and vortec with a little better quality. Its all a matter of personal preference.
Worthless might be your opinion but how many of those s-trims put out 500+rwhp and run almost 130mph in the 1/4.
Old Nov 8, 2003 | 10:50 PM
97WS6SCharged's Avatar
I think the Vortech units are much nicer than the 600b. If I had to do it over again, I might decide on the P1-SC since you don't have to punch a hole in the oil pan for a return line. Oh well, I'm getting ready to send my V1 back to Vortech and have em make a V2 out of it with the quieter impeller. A v1 sounds cool as all get out when it's making boost, but at idle it wails like a banshee. If you're going to invest in the supercharger, go ahead and get bigger injectors (dump the FMU), a better intake pump (the Trex is annoying after about 30 seconds), 160 t-stat, colder plugs, and some good programming (OBD1 conversion if possible). And yes, 6 lbs will wake your car up big time, how many other things can you do to gain 80-100 rwhp without refilling a bottle every week? Plus, the blower will grow with you, build a better engine, turn up the boost. Oh yeah, if you go over 6 lbs, get ready to rebuild the motor, the auto tranny or clutch if it's a 6 speed, and be ready for the rearend to explode. But other than that, enjoy
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cheapchevy
Apr 8, 2015 08:48 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
