How to tell again if block is a LS6?
Old Oct 30, 2003 | 04:18 PM
Black94mula's Avatar
The LS6 is a rougher casting right, and wheres the numbers to check?
Old Oct 30, 2003 | 04:47 PM
NEWBIE T/A's Avatar
Lightbulb From an old thread.
Unfortunately, the pics of the LS1 & the LS6 block no longer work.
See: http://web.camaross.com/forums/showt...k&pagenumber=1
I believe the answer was that if you look on the passenger side head closest to the intake there is a "bullseye" mark on the LS1 & none on the LS6.
If so, I have seen a LS6 block in an '00 car - the question is whether or it was replaced after production or not.
My '99 has the bullseye mark, thus it's a LS1.
Britt
Old Oct 30, 2003 | 05:37 PM
96SFLZ's Avatar
From what I understand, not all LS1s have the bullseye...so that's not a "for sure" way to tell. Although, if you do have a bullseye, then you know it's an LS1, no LS6 had the bullseye (99% sure about that).
If you don't have a bullseye:
To be sure that it's an LS6 block, you're gonna have to look at the block casting number. You'll find it on the back of the block...drivers side, above the tranny flange, where the head bolts to the block.
LS6 casting number: 12561168
LS1 casting number: 12559378
Formulized94's Avatar
does anyone know the casting number on the LS6 heads?
JJOHNROE
Parts Wanted
Oct 23, 2015 02:03 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
