max hp and torque for a 2-Bolt?
Old Oct 30, 2003 | 10:27 AM
silvertripper's Avatar
I've rebuilt my 350 (2-bolt) motor recently, but now I wondering how much can it handle? I'd like to push 350-400 hp, but does anyone have any idea what a 2-bolt generally can handle? Thanks!
Old Oct 30, 2003 | 11:31 AM
kacy's Avatar
get the splayed caps and make it a 4 bolt then no worries
Old Oct 30, 2003 | 12:20 PM
What are "splayed caps"
also, its already put together and in my car.
Old Oct 30, 2003 | 01:25 PM
kacy's Avatar
they replace the 2 bolt cap and they have to extra holes at an angle you drill into the block and it supposedly stronger than a 4 bolt
Old Oct 30, 2003 | 02:11 PM
oh I see, I wish I would have known this before building it.
So do you have any idea what this block can possible handle?
Old Oct 30, 2003 | 02:42 PM
81Z28355's Avatar
Build the engine to make power no higher than 6000 to 6500RPM and you should be fine, spin it faster than 6500 and your rods and crank might give you problems.
Old Oct 31, 2003 | 11:02 PM
NeverGonnaRun's Avatar
Most everything I've read, stock 2-bolts are good to around 430-450 hp at 6000 rpm. That hp rating starts falling off quickly as you spin it faster and faster.
Old Nov 1, 2003 | 07:46 AM
Greed4Speed's Avatar
I've seen many 2 bolt engines spin around 6k RPM on a dirt track and not have any bottom end failure.
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
realistyc
Jul 28, 2015 07:32 PM
