Ati P600b
Old Oct 29, 2003 | 06:31 PM
secretjade's Avatar
Ati P600b
I've seen allot of people say that the P600B sucks. Being that its the only supercharger I have had I don't know why "it sucks" It has been really good to me. If I upgrade to an F1 what benefits does it have? Right now I run 8psi but I am soon bumping it up to 12. Boost is the greatest thing
Old Oct 30, 2003 | 06:36 AM
IDOXLR8's Avatar
Re: Ati P600b
Personally I have had 3 blower rebuilds with the P600b. They didn't last for me at all. It was always something different. I think for a stock motor they are ok but once you go bigger cubes the blower becomes very inefficient. There is more to running an F1 than just changing blowers. You need a built shortblock, good fuel system, etc. It is not a cheap upgrade.
Old Oct 30, 2003 | 09:31 AM
secretjade's Avatar
Is it safe to run 12psi on a P600? I was thinking about getting a new pulley. Any ideas?
Old Oct 30, 2003 | 09:42 AM
IDOXLR8's Avatar
Are you running a stock shortblock? If so I would not recommend going over 8lbs of boost. If you have a forged bottom end then I would not run anything bigger than a 12 lb pulley.
Old Oct 30, 2003 | 11:48 AM
secretjade's Avatar
I do have a forged bottom end but what do I need to improve on to run more boost? I'm still new to this game, so I'm learning as I go.
Old Oct 30, 2003 | 12:20 PM
IDOXLR8's Avatar
Some people on this board have had some success running good times with their P600b. I personally think if you car is a 355 or a 383 than a D1SC is a better suited blower. What are your goals? Is this car going to be heavily street driven? What kind of budget are you working with?
96 WS6's Avatar
I know Ellis Groo ran a P600B to the max and it blew up and took his motor down with it... food for thought. You may want to talk to him.
Old Oct 30, 2003 | 01:21 PM
mongse_1's Avatar
With a built motor you should have no problems running 12#. Make sure you get enough fuel in the motor though. That's when trouble starts.
I ran a P600B for just over three years and never had any blower related problems. The P1SC is better in the sense that if you kill the blower, it doesn't blow metal shavings into the pan.
Old Oct 30, 2003 | 01:30 PM
IDOXLR8's Avatar
The biggest problem I would say with the P600b is when to start pushing it to the blower speed redline. I would give yourself a 5000 rpm safety margin.
Old Oct 30, 2003 | 02:06 PM
Bad AZz Z28's Avatar
they also make a 15lb pulley for the p600b if you dont think 12 will be enough for you, but ive seen alot of people on here say not to ever run it. from some quick math it looks like you wouldnt overspin the blower until 6400ish though (if i did that right, which i think i did ), so if people revved to 6k normally i dont see what the problem would be. always wondered if people had other reasons why not to run that size pulley with it?
Old Oct 30, 2003 | 02:14 PM
secretjade's Avatar
I think I'm going to go with 12psi for now. But I would like to go more in the future. I can't wait, I bet 4psi feels pretty good.
Old Oct 30, 2003 | 04:12 PM
ATMINF's Avatar
I also have a P600b and it lasted over 95,000 miles. When I did my rebuild for my motor, I also sent the blower back to ATI for new seals and bearings. So in my case I think the P600b is a good blower, but have to agree on higher boost levels the other larger units are the way to go.
Old Oct 31, 2003 | 05:57 AM
IDOXLR8's Avatar
I would highly recommend against the 15 lb pulley. Running this pulley brings the blower out of it's efficeincy zone.
Red_94Formula
Mar 7, 2015 09:21 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
Rybar
Jan 30, 2003 10:09 PM
SC97TA
Sep 15, 2002 01:10 AM
Black97Z
New England Area
Jun 18, 2002 09:39 AM
