So what can you tell me about turbo cams?
Old Oct 25, 2003 | 04:32 PM
BBB's Avatar
BBB
I understand NA cams. I REALLY know N2O cams. I am understanding/learning supercharger cams, but for the most part turbo cam specs elude me. I think alot of others are in the same boat.
1. What do I look for on the intake: lift and duration
2. What do I look for on the exhaust: lift and duration
3. Lobe seperation
4. Lobe shape/ramp speed?
What am I trying to do and when/why with the various timing events.
Last of all lets put a cam together for a couple of variables.
LT1 engine
1. 355 stock heads 15psi 9:1 compression
2. 383 ported GM heads 15-20 psi 9:1
3. 383 AFR heads 15-20psi 9:1
LS1 engine
4. 347 stock heads 9:1 compression
5. 382 ported heads 9:1
BBB
Old Oct 27, 2003 | 10:01 PM
wingnut's Avatar
BBB:
I thought someone would have responded by now, but for what it is worth I talked with sam at Combination Motorsports and he helped me pick out a perfect cam for my combo. It idles smooth and produces great torque. I think it is a CC 234 turbo grind.
See sig at bottem for results
Wingnut
Old Oct 27, 2003 | 11:35 PM
93formula's Avatar
they told me the 224/224 cam as well.
sts turbo as well
Old Oct 28, 2003 | 11:16 AM
marshall93z's Avatar
800rwhp on 93?
Wingnut
your kidding right...
Old Oct 28, 2003 | 02:44 PM
Tony Danza's Avatar
...........yes i second that motion.
Wingnut could ya please elaborate on how those numbers are managed?
Old Oct 28, 2003 | 08:03 PM
93formula's Avatar
metanol injection? BBB call up cam motion, they selected a 218/214 cam for me, billet for only 290. they really know their stuff.
Old Oct 28, 2003 | 08:34 PM
wingnut's Avatar
Sorry I did not respond earlier, but I just came in from the shop. The actual numbers look more like 792 rwhp and I suspect that there was some race fuel left in tank during dyno run. The reason, we just kept turning up the boost and no detonation. I thought I had pure 93 in the tank. After a refill, detonation started. we turnned down boost until gone. Now 702 rwhp with 57deg. F. intake air charge. Go figure. However, the car still gets over 23MPG during normal street driving. I just got so excited after the first day of runs that I had to change my signature. Now I just dont have the will to admit that there may have been c-12 in the tank. O-well, just pray for me.
In any way, I came out of the aerospace industry and put all I learned into desiging atmospheric equlizers (turbo systems in the automotive world). I build and design the systems myself and am now installing them on cars and trucks. The last system I designed was for a ram-air of mine and I built a top mount system much like the turbo Buick guys. I worked long and hard on the hedders and getting the flow numbers just right. This required the removal and re-installation of factory accessories in different locations. However, I did not install the AC. I was able to use a 3 3/4" down-pipe and exhaust system.
I have pictures of the system I will e-mail anybody if they want to see an alternative to the lower mount systems. The high mount design takes advantage of the flow characteristics of superheated air. I can provide some of my research papers if I can still find them.
By the way the STS system is, for the most part, very neet for a basic bolt on. I am jealous I did not think of it myself. O-well, good luck to the STS guys. They should make alot of money with thoes kits.
Feel free to ask any questions, I get online at night and will answer all I can. If you are in the Tulsa OK area, call me and come by.
BlownTA@valornet.com
918-688-6444
Wingnut
Old Oct 29, 2003 | 07:42 PM
Scott B's Avatar
Mines almost single patterned, it has little less dur and lift on the intake side, nothing too wild, could have been a drunken grinder This is all from degreeing it, it didn't have a cam card...the joys of custom cams
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
