changing window motors on my 94 camaro
Old Oct 24, 2003 | 12:13 AM
crasher88's Avatar
Hey all I have a 94 V6 camaro with power windows motos still from the factory and was hoping of replacing them with some new ones. My question is can I change out the motors I have now with some from like a 1999+. Are all the mountings the same and fitings confugred the same way or will I have to just break down andbuy a new one or can I go find a good working one from a junkyark and put it in. Any help would be greatly appreciated.
Old Oct 24, 2003 | 12:22 AM
99blackSS's Avatar
93-02 window motors are interchangeable. It's fairly easy to do but a little time consuming. I used the way that doesn't require you to take out the regulator.
Old Oct 24, 2003 | 12:41 AM
camaro6's Avatar
99blackSS is right i belive. All the window motors should be the same.
Old Oct 24, 2003 | 10:24 PM
crasher88's Avatar
thanks 99blackss and seeing how you have already gone through the process of changing out the motors do you have any tips or tricks that you would care to share to make my experience that much easier thanks
Old Oct 25, 2003 | 12:30 AM
99blackSS's Avatar
My only tip is doing it this way (click here) . At the bottom of the page theres picture and directions of each step. It's pretty easy but will probably take around 3 hours the first time.
Thanks to shoebox for doing the write up.
Old Oct 26, 2003 | 04:56 PM
CARdiac's Avatar
The window motors are not as difficult as you may think. If your current ones are working I would not change them....if you need help, I live in Houston and can help.
Old Oct 26, 2003 | 10:20 PM
crasher88's Avatar
well they are on the verge of failing my driver side window will only go up halfway before it stops and the passenger can only go up about 3/4 the way up before it stops
Old Oct 26, 2003 | 10:35 PM
CARdiac's Avatar
Following the instructions on the website is easy. If you need help, drop me an email.
Old Oct 28, 2003 | 12:49 AM
crasher88's Avatar
thanks for all the help guys I'm going to do the work tomarrow seeing how its my day off. And just one last question I want to put a new spoiler on my camaro. What I would really like to do is put an 02 ss spoiler on but are all the mountings and wiering configurations the same?
Jazsun
Dec 29, 2014 12:14 PM
NewsBot
Dec 28, 2014 06:20 PM
Snoman73
Nov 17, 2014 07:22 PM
