heads and cam plus nitrous questions
Old Oct 19, 2003 | 03:22 PM
zuluman13's Avatar
I know you can spray 150 safely on the stock bottom end. Will it be just as safe if say i was already putting out 400rwhp then a 150shot?
Old Oct 19, 2003 | 06:59 PM
RacinLT1's Avatar
as long as the fuel and ignition systems can handle it you will be fine.
Old Oct 19, 2003 | 08:50 PM
Wild1's Avatar
At a certain point, the stock hypereutechtic piston ring lands will collapse.
Old Oct 19, 2003 | 10:08 PM
RacinLT1's Avatar
im still looking for that point,174 hit for most of this year and no problems,guess it's time for 200....
Old Oct 19, 2003 | 11:20 PM
Wild1's Avatar
Yes, it seems to be hit and miss with the fragility of the hypereutechtic threshold. Maybe it has to do with the mix or porosity. Some cars can go up on the spray, while most can't pass 150 before crushing a ring land.
Old Oct 19, 2003 | 11:28 PM
zuluman13's Avatar
I dont want to do more than a 150 shot but i just wanted to make sure that heads and cam didnt effect what the stock bottom end can take as far as nitrous.
Old Oct 19, 2003 | 11:33 PM
Wild1's Avatar
LOL... sorry about the tangent. Yes, your heads and cam will not affect what your bottom end can take. The main weaklink in the bottom end are the stock pistons.
Old Oct 20, 2003 | 05:59 PM
rpm4lalo's Avatar
When I did the 100 shot shot on top of the cc306 I was seeing about 3-4 degrees of Knock retard, I could not run the 150 shot without major knock retard without a little bit of 103 octane.
Old Oct 20, 2003 | 06:14 PM
RacinLT1's Avatar
it is nuts to run nitrous on a heads/cam setup without race fuel.
make sure you run some good unleaded high octane (and not 94 sunoco) 100 octane unleaded at least.
Old Oct 21, 2003 | 10:11 AM
Wild1's Avatar
If you've got heads and cam, you've probably had programming done. If so, it sounds like the spark advance in addition to the N2O would create a bit of knock. You can do several things:
- Use race fuel (unleaded or you'll toast your O2s)
- Add a race fuel auxilary tank
- Reprogram to retard timing 2-3* degrees
- Add a timing retard controller to the interior
- Richen the mixture with a larger fuel jet
You may be starving the system too with 150 shots... may need to upgrade the fuel pump. You're at that threshold.
oldschool
Feb 9, 2016 09:21 PM
birdblack
Dec 30, 2014 06:59 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
