clutch and tranni question???
Old Oct 19, 2003 | 09:29 AM
CoUnTryMuZiCZ28's Avatar
Angry clutch and tranni question???
Ok, my car is acting up aside from being bottomed out.. the tranni wont shift smoothly into gears, it goes into all gears but it jerks around.. Is that master/slave cylinder related?? The the tranni i noticed has some oil(tiny tiny bit) on it... Is that little bit going to affect my clutch.. I know this is how it all starts from a little one but the rear main was just replaced... clutch grabs but i feel something giving out at the top end...
Old Oct 19, 2003 | 09:50 AM
NVetro's Avatar
Well the oil on trans an be blow by from an intake manifold leak OR a cracked washer on your oil pan bolt usally. You say the tranny is bangin around, it could VERY well be your trany mount, I would inspect it, see if its squashed/cracked. Our master/slave clutch units seems to either work or dont, they usally dont give a sign of it about to do. Since its a sealed unit, its either gonna be sealed and work, or have a hole and loose pressure and not work. Hope that helped.
Old Oct 19, 2003 | 10:31 AM
I mean the shifter jerks around... not the tranni.. you have to like push it into gear at a stop and cruising is fine..
Sergio
Jan 27, 2016 04:27 PM
HectorM52
Jan 30, 2015 11:08 PM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
mattszm6
Dec 14, 2014 07:09 AM
siguy
Nov 27, 2014 10:07 AM
