Any good sealer for Power Steering?
Old Oct 6, 2003 | 09:20 PM
therealmagyver's Avatar
I'm leaking power steering fluid. Any good sealers out there? Or is there some hose I should check or an oring? 90 for a used rack, 200 for labor and 45 for alignment is steep right now.
Could it be a bad pump?
Old Oct 6, 2003 | 09:42 PM
wrencher's Avatar
I like the lucas stop leak stuff, it'll help.
If it is pourin' out nothing will.
Old Oct 6, 2003 | 09:44 PM
I just checked it. Had someone turn the steering wheel while I looked for leaks. Well I found a spray!! Two pin holes it looks like from a weak or breakage spot. It's the larger hose coming out of the power steering fluid box. Anyone know the name for that hose or can point me to a part number.
I need a temp fix in the morning. Going to home depot. What should I get?
Old Oct 7, 2003 | 11:15 AM
dave1w41's Avatar
The high pressure side of the power steering system has as much as 1800 pounds of pressure in it. You can't temporarily fix it with anything. You need a new hose. It would be like fixing a brake line with electrical tape, on top of that, power steering fluid is flammable. Don't mess around, fix it right.
Old Oct 7, 2003 | 01:06 PM
Talking
I learned the hard way.
Thanks anyway.
HectorM52
Jul 30, 2017 11:46 AM
marineengineer
Feb 9, 2015 03:59 AM
Airplanedoc
Feb 1, 2015 07:14 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
