Crane gold series rockers interfering with springs
Old Oct 6, 2003 | 08:51 PM
davepl's Avatar
My new heads have a 1.530" outside diameter, which does not clear the Crane 1.6 ratio narrow body roller rockers (gold series).
I've ordered a set of Scorpion roller rockers, as they seem to have a much larger clearance for springs.
However, I'm really surprised I hit this. Is 1.530" that much larger than stock, and has anyone hit this with Crane rockers before?
Thanks,
Dave
Old Oct 6, 2003 | 09:13 PM
Lonnie Pavtis's Avatar
They will often hit on large diameter springs & also on some retainers.
The non-aligning units designed for 7/16" studs are machined for the larger spring & should fit without problem.
You can also grind the ones you have to clear with a die grinder & carbide burr. Strength should not be a problem as I have modified many sets without failure.
oldschool
Feb 9, 2016 09:21 PM
Sauced
Apr 12, 2015 10:18 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
