N.O.S. vs. NX
Old Jul 29, 2002 | 08:51 AM
stockLT1's Avatar
Thumbs up N.O.S. vs. NX
Anyone ever done a test on the dyno or at the track for the different systems/jettings??
I was told NX is a true HP increase on a 200 shot and a N.O.S. is like a 160...
HP differences??
ET differences??
Thanks guys,
-Scooba
Old Jul 30, 2002 | 11:23 AM
lt1lt1's Avatar
Talking
NITROUS EXPRESS IS A BETTER QUALITY KIT WITH MUCH BETTER FUEL DISTRIBUTION WITH THEIR SHARK NOZZLES. THAT IS WHY NOS DOESN'T EVEN MAKE WET KITS FOR YOUR CAR ANYMORE. YOU CAN SPRAY 300HP SHOT THROUGH A SHARK NOZZLE AND ONLY 90-150 THROUGH A NOS NOZZLE. BESIDES I HEARD THERE WAS A STOCK LT1 (AUTOMATIC CAR--WHITE IN COLOR) THAT CAN PROVE THIS POINT!!!!!!!!!!!!!!!!!!!!!!
P.S. GET NX!!!
Old Jul 30, 2002 | 11:55 AM
stockLT1's Avatar
Thumbs up
WHY DONT YOU BUY IT FOR ME THEN BUDDY!!!
P.S. YOU KNOW WHATS GONNA HAPPEN WHEN I FIND THE PROBLEM RIGHT??
'93 Z/28 M6 3.73's_6point cage_orange with yellow pearl_RK sport GFX_SS hood_RK sport hi rise wing_clear corners_billet grille_ported heads/intake_5 angle perf. valve job_97'LT4 383 by SELF RACING_CALLIES stealth crank_OLIVER six inch rods_J.E.forged dished pistons_10:1 compression
OLIVER splayed mains_custom grind cc306_LINE BORED_BALANCED AND BLUEPRINTED_FASTCHIPS custom chip and ED Wright DYNO tune_EGR bypass_home made SFC's_home made short throw_home made LCA's_home made CAI
Eibach Pro kit_ET Streets_Hooker ceramicoated LT's W/true duals and "H" pipe_Taylor Spriro wires_Autolite 104's_Aeromotive adjustable FPR_30# injectors,58mm TB, 1.6 comp pro magnum RR's
N.O.S. wet system 300 shot
_ ______________________ _
PAXTON S591 w/12 LB pulley in the works (need to custom fab some brackets)
Old Jul 30, 2002 | 06:57 PM
bt96ss's Avatar
Post
You know my answer. NOS=POS Been there done that. Never call them to ask for advice. They seem pretty clueless.
Old Jul 31, 2002 | 02:27 PM
lt1lt1's Avatar
Exclamation
I don't need to buy it for you. I will loan it to you for a night , then you will see "the way of the stock lt1".
P.S. 1WHITE1
Old Jul 31, 2002 | 02:55 PM
stockLT1's Avatar
Thumbs up
That will work I guess, but all your'e gonna see is my tail lights getting smaller and smaller as I leave you in the dust...BUDDY!!
Ya, NOS is pretty dumb, they told me I need to run 85 psi. and **** like that. I'm selling my kit and going NX, I'm tired of working on it every day.
Bryan...did you ever get your SS working right??
Old Jul 31, 2002 | 05:42 PM
KTamez's Avatar
Post
Nitrous Express is by far the more Tech friendly of the two. Holey turned NOS into a pile of crap.
StockLT1, Mind trimming that Signature down, 20 lines is only 4 times the 5 lines we try to have every one use.
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
Old Aug 1, 2002 | 12:36 AM
bt96ss's Avatar
Post
I'm going to switch headers in a couple of weeks(won a set of SLPs on ebay the other day) chandge the water pump and change the plug wires and go from there. I could probably just change the wires and it would be runing right but like you said I'm picky. Your buddy's car sounds alot like mine except he has a converter. You can't get away from those stock white NXed Lt1 autos can you.
Old Aug 1, 2002 | 01:24 AM
menlatin's Avatar
Post
I've heard that NOS rates hp to the motor, and NX rates to the wheels, so NOS isnt' letting anyone down , they are just rating it differently, so with NX you're actually just running more juice.
Old Aug 1, 2002 | 09:56 AM
stockLT1's Avatar
Thumbs up
Sounds like a plan Bryan...hope they work out better than the RK sport.
I'll be down this weekend.....I've got somthin for ya.
Later,
-Scooba
Old Aug 1, 2002 | 01:04 PM
lt1lt1's Avatar
Exclamation
HE (STEVE) DOES HAVE SOMETHING FOR YA. HE GOT A LITTLE HELP! BEWARE!!!!!!
Old Aug 1, 2002 | 01:57 PM
bt96ss's Avatar
Post
I'd like to hear about lt1lt1's car. What kind of times does he run. Is the throttlebody worth it at this level. Just curios is he 175 shot on a stock bottom end? I'm just full of quesions aint I.
Old Aug 1, 2002 | 02:32 PM
lt1lt1's Avatar
Lightbulb
I HAVE A BONE STOCK LONG BLOCK (NEVER HAD THE VALVE COVERS OFF)150 NX SHOT, LOTS OF OTHER BOLT-ON'S HOWEVER. I DO HAVE A 52MM THROTTLE BODY WITH AIR FOIL BUT DO NOT THINK IT IS NECCESARY ON STOCK MOTOR (AIR FOIL DOES HELP STAIGHTEN NITROUS FOG). LOTS OF $ IN THE SUSPENSION. RUN'S 11.60S ON RADIALS AT 118MPH. NOT THE QUICKEST, BUT A GOOD RUNNING FACTORY LONGBLOCK! I'M ORIGANALLY FROM OKC SO I WILL HAVE TO COME UP WITH STEVE SOME TIME TO MEET YA!
Old Aug 1, 2002 | 02:42 PM
lt1lt1's Avatar
Exclamation
P.S. I ALSO HAVE 86 FORD MUSTANG CONVERTIBLE WITH A 5.0 STOCK SHORTBLOCK (147,000 MILES) THAT RUNS 11.13 AT 124MPH ON E.T. STREETS.
Old Aug 1, 2002 | 04:22 PM
stockLT1's Avatar
Thumbs down
P.S. Thats not somthing I would be bragging about.....I'll put the convertible down just like I did your hatchback (white fords aren't fast, only white LT1's) Last time I checked, wasn't the convertible broke??>>typical ford...
seeya @ 6:30 BUDDY!!
-Scooba
