Nos Bottle Life?
Old Jul 18, 2002 | 07:37 AM
My84Z's Avatar
Post Nos Bottle Life?
How long are the bottle good for and do you have to test them ....
95 Z28 M6 with slp coated headers,slp 2otl cat back, cross drilled rotors, deleted maf screens,airfoil,slp sub frames, slp 160 thermo., slp skip shift elim.,slp air temp. module, slp cold air intake, Lt4KM, comp cams gold 1.6 rr's,lt4 clutch and pressure, energy supspension tranny mount, flowtech cutout, Taylor 8 mm wires over the valve cover, bf goodrich dr's, new best 12.88 with a 1.97 60'
88 jetta winter beater
87 honda cbr 600 hurricane fun to blast around on
Old Jul 18, 2002 | 07:50 AM
strokedTA's Avatar
From: Where people don't discriminate about your induction system.
Lightbulb
Bottles need to be tested every 5 years.
As long as they pass that they are good to go.
I had one bottle that was 20 years old and passed test just fine. I do this quite a bit. I sell used bottles with new powdercoating (any color the customer wants) and with brand new NX valves, Dirt Cheap.
Most have test dates from 2001, but most tracks don't even check the dates. It's up to you to keep up on them, it's your car and/or life.
Now the Carbon bottles CAN'T be recertified and for $500.00 a pop I don't really see the point, unless you have money coming out your, you know what, or are a Pro Mod driver needing to shed the very last little pound you can.
Good luck,
Dave Brown
If a little's good,
More is better,
And too much is just right!!!
[This message has been edited by strokedTA (edited July 18, 2002).]
Old Jul 18, 2002 | 08:30 AM
My84Z's Avatar
Post
where do you get them tested?
Old Jul 19, 2002 | 12:55 PM
speedmiser's Avatar
Post
Most any welding supply shop that does oxygen/acetylene refills can have the bottles re-certified for around 25-30 dollars. Also safety supply companys that refill medical grade oxygen, are also able to have the bottles certified.
It's usually a 3-4 day turn-around.
If I'm playin, I'm sprayin
93 Z28 A3 - w/ Jet Hot coated Hooker LT's and true 3" duals
(hiflow cats, cutouts, and Car Chemistry insert mufflers)
Old Jul 19, 2002 | 03:58 PM
strokedTA's Avatar
Post
I have a fire extinguisher place here do them for me.
Probably your best bet.
I get them done for $13.00 each.
Old Jul 19, 2002 | 05:41 PM
My84Z's Avatar
Post
thanks guys there is a welding place here that is gonna do it for me thanks again
Old Jul 20, 2002 | 07:29 PM
Sparkz28's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by strokedTA:
</font>
..........how much do you sell them for...I might need some.
Mark
94 Z28 m6
cold air,air foil,b&m ripper,vortech tb elbow,underdrive pulley ,flowbasterd muffler,moded maf,poly trans mount,fuel pres reg,exhaust cut out........new mods 355/with 12# of procharger boost
99 Camaro SS m6
#133
MTI air lid,some free mods,B&M Ripper,MacEwen Motorsports WFG with no high beam thingy....slp longtubes w/o cats,zo6 maf,z06 clutch,jet pcm,qt cut out
Big Red(truck)
406 ci,700r4 w/3000 rpm stall,3.73 10 bolt.
No more 406..kaboom / on the way 427 mighty mouse
Old Jul 21, 2002 | 05:54 PM
strokedTA's Avatar
Wink
Mark,
Just email me and we'll work something out.
Dave
If a little's good,
More is better,
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Sep 18, 2015 03:46 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
