Explanation needed!!!
Old Jun 27, 2002 | 02:47 PM
aBrotze's Avatar
Post Explanation needed!!!
Something has been bothering me about how nitrous is hooked up on a fuel injected motor. My brother has a big block chevy with nitrous. He has a separate fuel system for the nitrous and always double checking the fuel pressure to the nitrous system. Adjustments are done with a regulator (of course). He says that without the regulator the fuel solinoids would stick open. On my TNT kit for my 95 firebird, the fuel line for the NOS just plugs into the schraeder valve. Are solinoids on fuel injected systems designed to handle the high fuel pressure? I know 44 psi could not be handled by the solinoids my brother uses.
Any ideas?
Allen Brotze
95 firebird
LT1 edit, 58 mm
396 under construction
TB,6AL,Turbo 400, !cat,!cags,!egr,CAI, CSI electric waterpump
1 3/4 Hooker LTs
Mufflex exhuast
LCR's, Moser 12 bolt, Torque arm.
"Speed kills so you won't get hurt if you drive a Ford."
Old Jun 27, 2002 | 03:35 PM
strokedTA's Avatar
From: Where people don't discriminate about your induction system.
Post
LOL
How do you know his solenoids won't handle the N2O (not NOS!)?
The solenoids are the exact same.
You just have options on bigger higher flowing ones. They will work for high fuel pressure or low.
Your nitrous solenoids work with pressures near and over 1000psi and are built just like the fuel ones (basically).
Answer your question?
Dave
Old Jun 27, 2002 | 03:46 PM
aBrotze's Avatar
Post
"How do you know his solenoids won't handle the N2O (not NOS!)?"
Was referring to the fuel solenoids not the N20 ones.
Old Jun 27, 2002 | 07:44 PM
kmook's Avatar
Advanced Tech Moderator
Post
He was basically saying the noids are the same. So if the n2o noid can handle a 1000psi then 44psi on the fuel noid is nothing...
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • Almost Alive: ?rwhp & ?rwtq Naturally Asperated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Jesel Shaft Mount Rockers,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
Old Jun 28, 2002 | 10:32 AM
strokedTA's Avatar
Wink
Well, like Ken said..I know what you meant.
I know about the Noids, because I sell NX.
They are all the same (besides size/flow rate), from kit to kit, doesn't matter the pressure against them.
Dave Brown
If a little's good,
More is better,
And too much is just right!!!
DirtyDaveW
Dec 1, 2016 05:37 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
