LS1 Injectors?
Old Sep 17, 2003 | 10:28 PM
1995ta's Avatar
LS1 Injectors?
Will LS1 injectors supply me with enough fuel for a 125 wet shot? I'll be getting a racetronix fuel pump as well.
Old Sep 17, 2003 | 10:41 PM
Racetronix's Avatar
Depends on which LS1 injector you are refering to.
There are three part #'s that come to mind.
Old Sep 18, 2003 | 09:56 AM
slow's Avatar
agreed, on the 3 sizes.
But question? Why do you need larger injectors based on your sig, and a wet shot?
Ryan.
Old Sep 18, 2003 | 03:08 PM
1995ta's Avatar
Ryan.
I want adequate fuel and ignition for this nitrous setup I'll be doing this winter. LS1 injectors are bigger than LT1 injectors.
I'm going to use nitrous to get a mid to low 12
Old Sep 18, 2003 | 07:28 PM
RacinLT1's Avatar
you can keep the stock injectors and have plenty of fuel for a 125 wet shot. if you were planning a dry kit,then you might want to look into different injectors.
i have stock lt1 injectors and run a 175 shot to 11.0's with a stock longblock LT1.my car runs 12.36@109 without the bottle,so the stock injectors are fine with a good fuel pump.
the WET kit supplies it's own additional fuel,so you only have to worry about feeding n/a hp with the injectors and the nitrous will be bringing along it's own fuel enrichment.
Old Sep 18, 2003 | 08:44 PM
Racetronix's Avatar
LS1 injectors are 24lb and 28lb... pretty much the same as LT1 & LT4 injectors in delivery. Construction is totally different.
Old Sep 19, 2003 | 11:19 AM
And aren't the LS1 injectors rated and operated at 4bar (58psi)?
Meaning they will flow 15% less than rated in a 43.5psi LT1 fuel system.
Old Sep 19, 2003 | 01:55 PM
madwolf's Avatar
Yes, LS1 injectors are rated at 58 PSI. Year 99-00 26.4 injectors will actually flow less than stockers on our pressure and Year 97, 98, 01, 02 and 03 28.8s will flow just the same....
HarleyZ28
Oct 5, 2015 06:23 AM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
