Why not spray below 3000?
Old Jun 24, 2002 | 05:27 PM
z2894convertible's Avatar
Post Why not spray below 3000?
I was just wondering. I don`t have a stall convertor. I just got an NX wet kit and was trying to find out a few things before I put it on.
Old Jun 24, 2002 | 06:25 PM
gb95zconv's Avatar
Post
Short answer is ...you generate too much cylinder pressure at lower rpms when you spray...tends to break and bend things.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Old Jun 24, 2002 | 08:33 PM
red's Avatar
red
Post
You also run the risk of a back fire through the intake. Intake velocity over 3000 RPM usually is enough to eliminate backfire.
95Z M6
383
and a few other mods
Old Jun 26, 2002 | 02:34 AM
texlurch's Avatar
Post
example (true story)
had a guy with a 289 I built, was spraying a 75 shot, and had the button on his shifter. One night, him and his buddy are doing test and tune, and while he is turning around on the road (at idle, maybe a little above) his finger taps the button. It coughs once, then runs real rough, so he takes it home and calls me. The next day we pull off the valve cover and find two broken rocker studs, and 4 bent pushrods. Luckily that is all he hurt, and he added a hi/lo rpm switch that weekend. Cylinder pressure is a wonderful thing!
Texlurch - 68 Camaro (Just a little ol' LT1 with a Hot Cam, I SWEAR
" a little spray never hurt anyone, spank you very much!"
or the old standby:"I came here to race, not sell real estate. You ain't scared, is ya?"
Jeff1904
Jun 5, 2016 05:00 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
1slow93z28
Sep 1, 2015 06:22 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
