Please help me with my final clutch decision
Old Sep 14, 2003 | 09:42 PM
StephenF04's Avatar
Well...I got in my car today and find that my clutch is slipping even worse than it has been. I know that the Mcleod twin street is the one that will really hold. However I just don't have that much money. I do have the Vortech but I only see about 4.5#. That number will eventually multiply when I get the money for the rebuild. I realize then that I would need the Mcleod. Right now I'm not making that much power. So what clutch would you guys advise? Something that would hold until I saw a lot more power. As always your advice and opinions are greatly appreciated.
Stephen
Old Sep 14, 2003 | 10:28 PM
NVetro's Avatar
Spec Stage 2 with Spec Billet Alluminum Flywheel. If your gonna do ALOT of track runs then go with the stage 3 6 puck setup. Clutch it about $450 and flywheel is about $450 also, together, they are both cheaper then the $1000 or so for street twin without flywheel. Just my .02
Old Sep 15, 2003 | 09:35 AM
BBB's Avatar
BBB
Save your money and get the Street Twin, you will not regret it. I got mine last november for $904 (that included shipping/handling and it included the flywheel).
BBB
Old Sep 15, 2003 | 02:42 PM
StephenF04's Avatar
What about the Mcleod single disc. I've heard very good things about that. It runs around the price of the spec 2 . I have heard a 99 T/A running 10.40's all motor with this clutch. Just heard of this today...I'm considering this
Stephen
Old Sep 15, 2003 | 07:29 PM
67rs6sdd's Avatar
get the Street Twin got mine for 820 to my door look thru the group purchase section good luck.
Old Sep 16, 2003 | 06:58 AM
PatriotTA's Avatar
Stephen
I think you need the McLeod adj. master cylinder to run this disc. You definitely need it for the street twin, you could buy it now and then get a street twin setup minus the master cylinder (which is usually included, but you can order just the street twin). I talked to the McLeod tech guy and he said that if you have a blower or nitrous, the single disc won't hold. The single disc is good up to about 450 hp or so.
Old Sep 16, 2003 | 09:06 AM
StephenF04's Avatar
That is no good. Although right now I don't have 450 or anywhere close. 4.5# won't do too much. However sometime late this winter when I do the rebuild I should . I really don't consider the street twin an option. It's just too much right now. So excluding the Mcleod Street Twin, what would you all suggest? I THINK the single disc is around 440 but that's without the adj master cylinder. Thanks again for the replies
Stephen
Old Sep 16, 2003 | 10:55 AM
PatriotTA's Avatar
Stephen
You are correct about the price of the single disc. If you think about it, the Street Twin is worth the money. You get a flywheel and an adjustable master cylinder for the price. The master cylinder alone is about $250 and flywheels are $300-400 and up. So you get a lot for your money. If you don't want to spend the money on a Street Twin, you can go with a Spec stage III. I think that's about your only option other than the ST.
Old Sep 17, 2003 | 11:04 AM
camaroz28_97's Avatar
i whould just get the ST. in the long run youll be much better off. and like someone else said u get alot for what u pay for. i got mine for 810 shiped and love it. just do it once and do it right get the ST
Old Sep 17, 2003 | 11:46 AM
bowtieforpower's Avatar
clutch
the spec stage 2 clutch is a good one. it can handle 450 hp, and since you said your not close to that then you should be good.
pimpen1024
Aug 19, 2015 08:36 PM
Noct
Jul 14, 2015 01:18 AM
Boss002
Jul 9, 2015 03:33 PM
surreybrad
Jul 5, 2015 10:36 PM
