Hooker Headers for 3rd gen 2460's.
Old Sep 11, 2003 | 06:47 PM
91 Redd Sledd's Avatar
I have a set of Hooker 2460's that I bought for my Camaro but I will not be using them.They are in good used condition.They have Black paint,It might even be original.It is not burned off.I do not have the attaching Hardware but have a set of gaskets to go with them.These are the 1 5/8 headers with NO AIR TUBES.Would look sweet Jet Hot coated which is what I was going to do but decided not to.Asking price is $100.These headers are not junk.Headers have a O2 Bung but it has not been drilled out.
James
Old Sep 11, 2003 | 08:06 PM
FLIPPINZ28's Avatar
hey are these long tubes and will they fit my 92 rs 305
Old Sep 11, 2003 | 08:50 PM
they are considered "Shortys" I guess. They would fit on your 92 with no problems. You would have to take the car to a exhaust shop to have some work to mate them up with your Y-pipe. They are not a true bolt on like on the Mustangs with the Ball and socket type fittings.Some fabrication work is required. I had the same ones on my 86 T/A and I loved them.They are clean looking when installed due to not having airtubes on them. I just checked them out again, I believe they have the original paint on them.I can tell that they have been ran but the paint is still there.
James
Old Sep 12, 2003 | 03:03 AM
FLIPPINZ28's Avatar
what do you mean not a true bolt on
Old Sep 12, 2003 | 05:15 PM
By True bolt on, I meant like on my Mustang when I put shorty headers on that car it was 100% bolt on.The headers mated up to the heads and the factory H-pipe bolted up to the collectors using all of the factory hardware with no other modifications.On the Hookers I am selling, The headers bolt to the heads just like the factory manifolds did.The collectors on the other hand will not directley bolt up to the Camaros factory Y-pipe.You would have to take it to an Exhaust shop to have a set of collectors welded to the factory Y-pipe or have a custom Y-pipe made(Your Choice).Therefore in my opinion it is not a 100% bolt on like on the Mustangs. Pretty much no matter what header you choose for a 3rd gen camaro it is not a 100% bolt on as described above.You will also have to make other modifications.
James
Old Sep 12, 2003 | 05:20 PM
FLIPPINZ28's Avatar
so is the y-pipe the only mod i will need to do
Old Sep 12, 2003 | 05:57 PM
Zepher's Avatar
Do they look like these?
http://www.jegs.com/cgi-bin/ncommerc...51&prmenbr=361
The picture shows a longtube header.
Old Sep 13, 2003 | 06:02 AM
No, they do not look like those in the picture.That was the right part number,but the wrong picture.Summit usually has a picture of the actual ones I have in their magizine.Yes Modifications to your Y-Pipe should be the only ones you should have to do.
James
Old Sep 15, 2003 | 02:39 PM
TTT
Noenav
Mar 1, 2019 07:38 AM
QuickSilver02
Apr 7, 2015 11:12 AM
jasonduaine
Apr 1, 2015 08:09 PM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
