pros, cons, and info about 160 themo on 3.4
Old Aug 10, 2002 | 02:09 PM
CLEAR's Avatar
Post pros, cons, and info about 160 themo on 3.4
i really dont know that much about them. help me out guys.
Old Aug 10, 2002 | 06:27 PM
Ryan94V6's Avatar
Post
Just get it .......it keeps your engine a few degrees cooler just for a couple bucks.
94 3.4L Camaro A4 (Stock)
Old Aug 10, 2002 | 06:49 PM
NeoPaladin's Avatar
Post
Basically, a lower thermostat will open sooner, causing coolant to flow through the engine block sooner, and making it cooler. Cooler, of course, means denser air intake, meaning more power.
Of course, this is all in theory.
Since the 3.4L is a fairly compact iron block, it heats up fairly quickly for such a small motor. It also makes a lot of heat.
That said, even with the 160 thermo, you'd probably still be running at about 180 degrees on the freeway. More than anything, you'd likely wear out your coolant sooner.
asilomar244
Jul 12, 2015 05:53 AM
colts0455
Jul 8, 2015 12:21 AM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
cristian1311
Apr 22, 2015 10:20 PM
