Throttle Body Bipass
Old Aug 2, 2002 | 03:16 PM
Luke4212's Avatar
Post Throttle Body Bipass
I have seen this item up for sale at Ebay and was wondering if it was worth the price. $6-$14 depending on shipping. I drive a 2002 stock V6 and was wanting to do a few mods. I was also looking under my hood and did not see anyway to do this mod and wondering if anyone has any ideas?
Old Aug 2, 2002 | 03:50 PM
redcamaro9090's Avatar
Smile
I could be wrong, but I don't think there is a TB bypass for the 3.8l engine, just for the 3.4 and the V8s(i think) also.
Old Aug 2, 2002 | 04:19 PM
Perfecto's Avatar
Question
How do you do the throttle body bypass and what does it do?
Black 94' 3.4l Camaro A4
Old Aug 2, 2002 | 08:32 PM
MustangEater82's Avatar
Post
basically what a TB bypass does is it there are 2 hoses connected to your TB, they have engine coolant gong through them to help warm up the TB on cold starts, and prevent ice crystals form forming or something liek that. Either way, you basically dissconnect the 2 hoses and put on in its place or do what i do and cut the two lines and recconect them with a hose repari kit.
$13 not worth the money, took me 5 min. to do it with a razor, $2 hose repair kit form discount auto, and 2 small hose clamps that are like $0.50 a piece.
Maybe a little bit of a performance ggain on a hot day but not much.
1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed
Homeade CAI with a huge K&N cylinder filter, Single outlet Flowmaster with resonator, Accel 8mm ignition wires, Rapidfire plugs, 3.42 gears and posi off a 97 WS6, 1 piece steel driveshaft, Converted to 4-wheel disc brakes, 1LE transmision mount, 1LE sway bars, Prothane bushings and endlinks, BMR Strut tower brace, ASP underdrive pulleys, 160* stat
Lightest Weight W/out driver: 3160
15.696@86.22 with a 2.214 60'!
Best R/T .507
Best 60' 2.106
Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed
15.875@88.25 With wheel spin in 1st
15s are cool!
AIM: MustangEater82
Old Aug 3, 2002 | 06:26 PM
nikkev's Avatar
Cool
If you have a 3.4 then you don't need anything but a screwdriver.Just attatch the TB tubes to themselves and attatch the radiator line to itself.You can do that using both stock hoses and clamps with no cutting.They are usually stuck on there though so you have to pull pretty hard to get them to come off!This mod helps by keeping the incoming air cooler.A 1996 (I think) LT1 TA picked up about 7 rwhp over stock on a dyno.Even if it's not a lot,every little bit helps!
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Pics
Camaro/Firebird Birthday Bash
Old Aug 4, 2002 | 03:24 PM
MysticTeal 95 V6's Avatar
Post
Its a very easy mod to do... I did a little page on it a couple years ago. Its on my old CZ28.com site so don't pay attention to anything else on there
http://rich.cz28.com/tbbypass.html
Hope that helps.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
