Spay on stock plugs???? good.... bad???
Old Sep 9, 2003 | 10:44 PM
Xride's Avatar
Well I think I'm going to get my kit installed befor the last track day befor winter here, but I wont have time to do my plugs or wires,
Will it still be safe to spray a 150 shot NX? this will be one night, maybe the bottle, and then it will be new plugs shortly there after.
can I do it or no?
Old Sep 9, 2003 | 10:46 PM
TMDZ28's Avatar
better be safe than sorry dude
change it to autolite 104 or 103
Old Sep 9, 2003 | 11:20 PM
RacinLT1's Avatar
1 night of a 150 hit will wipe the platinum pucks right off the stock plugs. just swap em out now.
PnchoPwr's Avatar
with a 150 shot I would go one or two heat ranges cooler on the plugs.
Old Sep 10, 2003 | 06:48 AM
Derrick Redd's Avatar
Change those plugs.
Old Sep 11, 2003 | 03:09 PM
DTABFORMULA's Avatar
i say CHANGE them definately and dont use platinum u will melt those platinum pluge..
good luck
Old Sep 11, 2003 | 07:00 PM
rpm4lalo's Avatar
For a 150 wet shot, just buy some Autolite 104's and gap them at .035 to .039
Old Sep 11, 2003 | 07:41 PM
Xride's Avatar
I know to change the plugs, but I wont be getting headers till the winter, and I was planning on changing the plugs at the same time. but for the one night will I f my plugs up or not?
Old Sep 11, 2003 | 07:44 PM
rpm4lalo's Avatar
I would change them now.
Then when you do headers, you can examine them and see how they have held up.
No one here is going to tell you it is okay to run a platinum plug with a stock gap with a 150 wet shot.
Old Sep 11, 2003 | 08:10 PM
Xride's Avatar
good point, what about a 75 or 100 shot even?
air temp should be cool too cold, ~50F if that makes a difference.
I'm going to try my damndest to change the plugs, but from what people have said it is a real pain in the *** with the stock manifolds.
Old Sep 12, 2003 | 12:05 AM
TMDZ28's Avatar
with the stock manifold changing the plugs is a lot easier than having shorties or longtubes in there.....change em before you spray. dont matter if you spray 50 or 400 shot, platinum plugs + nitous =
HectorM52
Jul 30, 2017 11:46 AM
grabbem88
Feb 13, 2015 03:09 PM
Amshnock
14
Jan 18, 2015 11:47 AM
cmdeshon
Dec 27, 2014 10:06 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
