Question for people running 5.7" Eagle H-Beam Rods
Old Sep 7, 2003 | 09:00 AM
Arctic_White_WS6's Avatar
On a LT1 383 stroker with these rods, do I have to use an aftermarket oil pan or will the stock pan work?
Thanks,
Brent M.
Old Sep 7, 2003 | 09:43 AM
Eric Bryant's Avatar
You'll likely have to modify the pan rails to clear the rod bolts.
Regardless, I view this as a bad idea, due to the lack of sump depth along the front of the pan - it's just asking for windage problems. A deeper aftermarket pan is a very wise investment, based upon my experiences.
Old Sep 7, 2003 | 11:32 AM
Andrew Coats's Avatar
I just built a 383 with H-beam rods and I had to go with a canton pan. The rod bolts we're hitting the stock pan even after we clearanced it.
Old Sep 7, 2003 | 02:46 PM
thewinner's Avatar
i am using the stock pan with those rods. just need to punch it out in some areas.
Old Sep 7, 2003 | 03:10 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
THe Eagle H- Beam 3D rods are supposed to be stroker clearanced when yo buy them. DId you get the 3D rods?
Old Sep 7, 2003 | 05:54 PM
gb95zconv's Avatar
Hummm...thats odd mine cleared fine. Did take me a while to figure out that I had to do some clearancing on the side of the pan where it bolted to the block in on place.
Old Sep 7, 2003 | 10:11 PM
red's Avatar
red
I am using the stock pan with mine. Just had to make the right dents in the right areas.
Old Sep 7, 2003 | 11:01 PM
Kyle@CSS's Avatar
Are you still using the windage try? Im building one, and I put washers between it to space it down. The bolts were hitting it also.
Old Sep 8, 2003 | 07:47 AM
You can buy a melling windage tray and clearance the sides of it where the rods are hitting. I had to take out 3 small sections on each side of the tray to make it work with a stock oil pan.
Old Sep 8, 2003 | 08:13 AM
The "clearanced" rods are slimmed-down where the big end meets the beam of the rod, but this only provides better clearance to the cam and the lower parts of the cylinder wall - it doesn't affect the clearance of the rod to the oil pan rail.
Old Sep 8, 2003 | 07:55 PM
RCF925's Avatar
Just finished a 385 and went with the stock pan. I have a Callies Dragonslayer Crank & Eagle 4340 H-Beam rods with ARP bolts. I had to massage the pan with a BFH for #1 & #2 rods hitting the bottom and Pound out the side a little where #7 was hitting. No problems after that and I'm using a windage tray with Melling HV pump.
Old Sep 9, 2003 | 10:37 AM
bkrepindy's Avatar
No problems here. I used 6" eagle h-beams and a Canton pan. I didn't have any clearance problems whatsoever.
LeftoverChinese
Jan 14, 2024 03:03 PM
oldschool
Feb 9, 2016 09:21 PM
Catmaigne
Dec 25, 2014 12:16 PM
Hurin
Dec 13, 2014 07:38 PM
jayblev95
Dec 1, 2014 06:55 AM
