vortec heads
Old Aug 21, 2002 | 11:53 PM
Matt96Z's Avatar
Post vortec heads
since you can install vortex heads on an older block will the full injection system bolt right up too if you use vortex heads
Old Aug 22, 2002 | 01:11 AM
BluEyes's Avatar
Post
well, you'll need all the sensors, and wiring harness, but it should bolt up fine.
You'll have to look into how adaptable the ECU is - you might have to have a new chip burned for your combo.
You could also take the factory EFI manifold, fuel rails, injectors, etc and hook it up to an aftermarket ECU - that way you can tune the engine the way you want it, and not worry about anything else confusing the computer.
also, I'll bet the ECU for the Vortech motors wants an electronic speedo input. There is a place that makes a piece to convert your cable speedo to an electronic output, but you'll need an electronic spedometer then.
Old Aug 22, 2002 | 05:41 AM
mrgto's Avatar
Post
Nope. You need a manifold that is for the Vortec heads.
Old Aug 22, 2002 | 11:44 PM
Capn Pete's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by mrgto:
Nope. You need a manifold that is for the Vortec heads. </font>
I think he meant an intake off a newer fuel injected motor, so YES, like BluEyes said, if you got all the electronics hooked up, you could use the fuel injection on the old block with vortec heads.
2002 Z28 - A4, 2.73's, Blk/blk, leather, T-tops, sport appearance package - just bought on June 26, 2002! - Pics
1981 Z28 - 383, TH350 trans., 3.42 posi - sold August, 2000 - Pics
1973 Camaro - Dad's & my project in the works - to be built: 355 Chevy, 11.5:1 pop-ups, "camel hump" heads (w/2.02 valves), solid cam, 4-speed.....it should be quick! - Pics
Old Aug 26, 2002 | 01:42 PM
LT1 1980 malibu's Avatar
Post
Youll have a hard time getting a crank sensor to work on the old school block but other than that yeah..
FLUCK A SPELL CHECK&lt;I CAN SPELL REALLY GOOD&lt; IT'S JUST THE TYPEING THAT STINK AT!
http://phillyfabanddesign.tripod.com/parts4sale/
http://phillyfabanddesign.tripod.com/phillyfabricationanddesign/
http://phillyfabanddesign.tripod.com/PhillyFabsLT1RX7/id1.html
88 RX7 GTU, 97 Lt1/700R4,10" 3K stall, 4.30 gears,285CFM heads,12.4-1 compression, custom cam and 2700lbs...Daily driven!
dfarr67
Apr 10, 2015 07:44 PM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Lakebratt
Feb 5, 2015 07:55 PM
Chris Anderson
Jan 27, 2015 08:30 AM
InfernalVortex
Jan 17, 2015 09:35 AM
