View Poll Results: Which Clutch Would You Go For?
Spec
26.67%
Centerforce
13.33%
Ram
13.33%
McLoud
46.67%
Voters: 15. You may not vote on this poll
Post your Experience with Different Clutch Brands?
Old Sep 5, 2003 | 04:04 PM
ls1z01's Avatar
Thumbs up Post your Experience with Different Clutch Brands?
I'm in a need of new clutch soon and I have heard all sorts of complaints and complements on the sames clutch such as Spec, Centerforce, etc.
Post for me your experience with the clutch brand you went with and how is it working out with yours? Good quality? bad quality? just a bad clutch?
I know there is a huge difference in price of different clutches out there but i'm aiming at the experience & quality rather than going for the gourment brand to get braggin rights
Old Sep 5, 2003 | 06:22 PM
camaroz28_97's Avatar
deff the mcleod. there a lil hard on the rear thought ... see sig
Old Sep 6, 2003 | 03:38 PM
sikz28's Avatar
I'd like to know the answer to this too. I know centerforce sucks and my star really sucks. I guess I just need to build up a motor so I'll need the mc cloud.
Old Sep 6, 2003 | 08:26 PM
hotrodgirl's Avatar
I really like my Mcleod single-disk clutch (I wanted to keep something streetable). There was very little chatter when I was breaking it in but now there's none and the engagement is smooth. It grabs like crazy-I can light 'em all the way to 4th. I would recommend it.
Old Sep 7, 2003 | 03:39 AM
ls1z01's Avatar
Does the McLeod Clutch Single Disk need to go with McLeod Adjustable Master Cylinder? or will my 01 Z28 Master Cylinder worth with it? Cost is a factor. Because if someone can validate a McLeod Clutch that can last 2 or 3 time of that of SPEC / Centerforce / RAM then it's worth the investment.
Also I heard of the springs on the SPEC clutch plates poping out? what is the deal with that?
Tom
Old Sep 7, 2003 | 10:13 AM
hotrodgirl's Avatar
I'm can't say for sure, but I don't know why you couldn't use the stock master with it. I changed mine because I have a '98 and it's recommended that you update the slave and master with certain year models (I believe up to 2K)
Old Sep 7, 2003 | 10:20 AM
Josh'95Z28conv's Avatar
No problems here with my Spec stage 2. Holds good even after smoking it a couple times at the track. About 15k miles so far, no problems whatsoever. Im impressed.
Old Sep 9, 2003 | 04:10 PM
ls1z01's Avatar
Physically what is the difference between SPEC stage 2 and 3 clutchs? Clutch Plate? or Pressure Plate? or both? anyone has pictures?
Old Sep 10, 2003 | 01:45 PM
firepheasent's Avatar
1 more vote for the Mcleod SINGLE kevlar/organic disc.
great clutch and Ive been RUFF with it. You can use your stock Master set up and do the drill mod to the slave/throwout bearing for quicker engagement and all will be well !
Old Sep 10, 2003 | 10:35 PM
m0nk's Avatar
My spec stage III broke :/ Now i have the Street Twin.. only 150 miles into breakin thou so I cant say to much about it.
Old Sep 11, 2003 | 02:21 PM
kgkern01's Avatar
Spec uses very tiny springs in their clutches, at least in their 6-puck Stage 3. Went through 1 from Sept to Jan (caused by bad pilot bearing and tranny) rebuilt everything with pilot bushing instead of bearing so less play, then in July went through another one, both times blowing the springs. Had the transmission checked for excessive play or runout, was still within specs, did some research, made some calls, turns out, Spec uses the SAME spring center hubs from their 4-cyl clutches as on their LT1 clutches. Didn't believe local clutch shop till he showed me them side by side. Made in China part also. No more Spec for me, going to get something that holds up next time. This was on a basically stock daily driven car with only intake and catback mods and NO track time or racing.
Old Sep 11, 2003 | 04:12 PM
rskrause's Avatar
Moderator
The McCleod is a great clutch. Only problem is that it's expensive.
Rich Krause
chevy95z28
Jun 22, 2015 09:28 PM
HectorM52
Jan 30, 2015 11:08 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
