70's 350's
Old Aug 10, 2002 | 08:02 PM
BillyBigBalls's Avatar
Post 70's 350's
i sold the 400 outta my car for some $ and he also gave me a 70s 350 for put in it.how are theses motors?can they be built up any pretty ez?or r they just to slow to even want to build up?overall how are they?
Old Aug 10, 2002 | 09:49 PM
IRONFIST's Avatar
Post
Chevy 350's are more then decent engines... the pontiac ones suck.
Cherry Black '76 Firebird,400,COMPXE268 ADV 2*,6X-4'S (8.4:1),PERF-RPM INTAKE,2.46's,1,5/8"headers, 2.5" duals, TH350...
2002 Cavalier, daily driver, no mods. 17.337@79.80mph@3500'
Old Aug 10, 2002 | 10:53 PM
Post
i think its a 75 or something.how can i wake this thing up?
Old Aug 11, 2002 | 12:13 AM
Capn Pete's Avatar
Wink
How can you "wake it up"???
EASY!!!
Even with stock heads, you can add a high performance camshaft (the "brains" of the whole motor) and get a significant power improvement. Old 350 small blocks are a cheap engine to rebuild and to get parts for, so stuff like the cam and pistons, etc. aren't going to cost an arm and a leg.
A motor built in ~'75 is not going to be like one built in the late '60's --- emissions were suddenly becoming important, and high-horsepower engines went out the window. The pistons are almost guaranteed low compression, dished pistons. Get flat-top pistons at least, and if not, pop-ups are even better! These will boost your compression ratio up significantly, and then if you have a good camshaft, you should have a good motor pretty cheap.
You can spend more money on stuff like aluminum heads, roller rockers, etc., and they will yeild you even more power. It all depends on how much you want to spend to make power.
But a 350 SBC is by no means a "slouch"!!! (well, when built right! )
2002 Z28 - A4, 2.73's, Blk/blk, leather, T-tops, sport appearance package - just bought on June 26, 2002! - Pics
1981 Z28 - 383, TH350 trans., 3.42 posi - sold August, 2000 - Pics
1973 Camaro - Dad's & my project in the works - to be built: 355 Chevy, 11.5:1 pop-ups, "camel hump" heads (w/2.02 valves), solid cam, 4-speed.....it should be quick! - Pics
Old Aug 11, 2002 | 01:30 AM
Post
the motor looks sorta crappy looken,runs fine,but it looks worn out,how much wood it cost me to get my car runing low 15s with this motor?
1986 Grand Prix engine swap with a 73 big block 400.
Old Aug 11, 2002 | 01:15 PM
AJ1978TA's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by BillyBigBalls:
</font>
My trans am with a 400 pontiac motor, 200 hp MAXIMUM stock, ran 15.2 with Headers, dual exhaust, no cats, and an open hood scoop. So, get a good carb, headers and true dual exhaust without cats, maybe a K&N, and you should be there.............I had more torque though........It shouldn't take a lot...lots of factors, depends on the car as well, etc etc......
1978 Trans Am, will be alive soon, engine being rebuilt.....I'll get out of the 15's someday... http://www.cardomain.com/member_page...=225185&page=1
Old Aug 11, 2002 | 09:04 PM
Post
anyone no how much it wood cost me to rebuild it?if i add performence parts to it it will mess **** up cost the motor is stock and looks like its a lil worn out.will my car sound tuff with this motor ifi put on some flowmaster?my car weighs around 3600lbs with driver.my aim name is StickyHydro318 hollor at me plz.
Old Aug 11, 2002 | 09:23 PM
Post
actually i think my car weights 3175lbs w/o driver,it looks alot heavyer tho
Old Aug 13, 2002 | 12:59 PM
drewhelm's Avatar
Post
If pontiac 350's suck why is one in the PHR engine building contest? I think it's funny that people throw away a decent engine because of what they have heard from someone who knows a guy who dates a girl who had one that sucked. LOL The Pontiac 350 is the SAME block as the 400, 428, and 455!!! Hell take a Pontiac 350, bore it .125 and viola! you have a friggin 400!!!!
Sorry, had to step in there....I have a 350 that I swapped out for a 455 anybody want it?
Old Aug 13, 2002 | 02:14 PM
Post
i do i do.i had a 301 in my car and it sucked *****,right now i got a chevy 350 in it.
Old Aug 13, 2002 | 08:43 PM
Dr.Mudge's Avatar
Post
From what I recall, a Pontiacs made in Canada got Chevy engines.
Pontiacs can make good power, but more expensive and harder to find hop up parts compared to SBC
[This message has been edited by Dr.Mudge (edited August 13, 2002).]
Old Aug 13, 2002 | 11:55 PM
Bill B.'s Avatar
Post
Yeah, and since that Pontiac 350 is the same block as the bigger motors, it is probably a pretty heavy motor too.
Not badmouthing the Poncho motors, but it's much easier to find the performance parts and less expensive to get more power with a Chevy 350.
Bill B.
Old Aug 14, 2002 | 10:19 AM
Eric77TA's Avatar
Post
The Pontiac 350 isn't a bad motor and it can be made to run pretty well, but as has been mentioned it is heavy. The other big strike against it is all other things being equal, it's actually cheaper to build a 400. Pontiac 350 pistons, etc. are actually more expensive than the 400 pieces.
Old Aug 19, 2002 | 04:17 PM
drewhelm's Avatar
Post
That's funny. The ONLY internal parts that are different are the pistons and rings. These are priced VERY comparably. Crank, Rods, bearings, cams, cam bearings, main caps, etc, etc, etc are identical to the 400.
The Shortblock I have is exactly that....only shortblock and rotating assembly. Crank, rods, and pistons still installed. I will throw in a cam and timing set. $150, plus shipping. I can ship via forward air for around $200 to a major airport near you!
Old Aug 20, 2002 | 12:15 PM
Eric77TA's Avatar
Post
All other things being equal, 350 pistons are typically more expensive. Intake manifold, cam, carb, whatever other upgrades you want to throw on cost the same, sure, but when you're done you have a 400 horse 400 and a 275 horse 350.
