mild perf cam for a stock 454
Old Aug 20, 2002 | 02:37 PM
yzguy's Avatar
Post mild perf cam for a stock 454
My dad has recently acquired a 69 wagon, and has a stock 454 out of a 77 truck (probably all original, all stock).
Wants to put together the wagon, BBC TH400, stock rear end and gears (no idea, right now what but probably not ideal).
We both know it will not be a monster but want to do a mild perf cam (with a noticeable but not dramatic lope) alum intake, and headers just to wake it up a bit.
what cam would you guys suggest?
69 Camaro among other toys.
Old Aug 21, 2002 | 02:50 AM
texlurch's Avatar
Post
I would look at the Comp Cams Extreme 4x4 cams, they are just what you need to make torque, and have a lope, and also work with all your power accessories and a/c. I would stay around 268 degrees advertised duration or less, if you want a daily driver. Add a performer intake (or similar), and about 9 to 1 compression, and enjoy
Texlurch - 68 Camaro-LT1 w/Hot Cam, TT & TIC coming soon!
" a little spray never hurt anyone, spank you very much!"
http://camaroz28.cardomain.com/id/texlurch
Old Aug 21, 2002 | 02:32 PM
yzguy's Avatar
Post
well we were looking around and found the Summit cams for $75.. the comp cams had more selection (probably a better suited one) but at more than 2X the money it just was not worth it for this.
this will be put together and played with for a short time, then probably sold so we will see what the summit one will do
218/228 with .500/.500
about the lift we wanted but not quite as much durration.... oh well, we'll see how it works out...
thanks.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
pimpss96
Feb 12, 2015 01:28 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
