Axle question...
Old Sep 5, 2003 | 12:59 AM
KwikistZ's Avatar
Axle question...
If I got like 12 inch wheels in the back of a Z28 and didn't want them to stick out, and I wanted them to 'stick in' how would I go about doing that?? Like move the wheels/tires closer to the diff. See what I'm saying? Thanks!
Old Sep 5, 2003 | 05:33 AM
anaik's Avatar
Biggest I've heard of anyone doing is 11" Wheels. Here's a couple of links.
http://u2.netgate.net/~jshapiro/z28/315s/index.html
http://www.afswheels.com
Old Sep 5, 2003 | 02:23 PM
JWINN's Avatar
In order to get your wheels and tires in closer to the center of the car your looking to either narrow the rearend housing or you could try getting a rim with a larger bag spacing. I have told that the largest rim you can get under a car without cutting the wheel well put will require some hammering to the inside of the wheel well will either be select rims such as Fikse has a 17x11 with a large back space that fits or drag wheel will be 15x10 with a 7.5 back space. Anything larger you will have to mini tube the stock tubs. I just redid my whole chassis from the firewall back and I run a 31x16.5x15 MT ET Street but I also changed alot of items to do this. My rims on the rear are a 15x12 Weld Aluma Star.
Good Luck
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
force10
Jul 30, 2015 04:56 PM
realistyc
Jul 28, 2015 07:32 PM
